Full Version: cross calling ppl and #cas ???
So what are the argument and evaluation rules when
(1) a ppl function calls a #cas func
(2) a #cas function calls ppl
(3) a ppl fun passes cas variables
I get different results and sometimed brutsl crashes
depending on the args and functions.
Easy answer: I can't even remember!
Ok, looking in the code, here are the rules:
From PPL to CAS
- Parameters are NOT evaluated prior to the CAS call Unless it is a list
- All local variables in the parameters are replaced by their values (because CAS does not have access to local variables)
- Parameters which are Strings are parsed by the CAS parser
- CAS default variable is changed to X, Y and theta depending on the current app
- CAS function is evaluated
- CAS default variable is restored
- CAS Result is transformed into PPL construct and returned
from CAS to PPL
- All arguments are evaluated
- Arguments are transformed into PPL constructs and PPL function is called
- Result is transformed back into CAS and returned
Cyrille
I presume you mean the CAS (....) call.
How about calling a #cas function.. from ppl?
e.g.
#cas f (a,b):=......#end
then in ppl call f
a:= f (n,m);
Anything different here?
(10-05-2015 03:27 PM)ji3m Wrote: [ -> ]I presume you mean the CAS (....) call.
e.g.
then in ppl call f
a:= f (n,m);
He means all instances of calling a program or command name that is associated with the CAS side of things. So whether it is a function you created using #cas or a built-in CAS command, what Cyrille posted is an explanation of how inputs are parsed when calling a CAS command/program from within a PPL program or calling a PPL program from within a CAS program. The CAS() command is a PPL command as is the CAS.command() construct.
