10-02-2015, 11:31 AM
Here is my first program, a virtual keyboard for the prime, because changing orange key can't be performed by a firmware update
Well, don't be too enthusiastic, it's a first version, I had 2 free hours, it's only a "Proof of concept", it's ugly and not yet feature complete.
But at least, here are working features :
* moving cursor with left/right keys
* accept entry with ENTER key (or tap on right side)
* cancel entry by ESC key
* adding char at the end of the or in the middle (depending on cursor location)
* removing char at the end or middle... with "<=" (del) key.
* space key to add a space
* blinking cursor
Run the program with vkb or in USER mode with alpha dot key (.)
As it's a very first version, you may encounter bugs, you are wellcome to report it.
Note
I had trouble to work with MOUSE(), there is probably a way to enhance what I did, if someone want to take a look at my getmouse() function to leave me advices. I'm not sure if I should better check for MOUSE(4)==1 for type or not...
There is a feature that is not developed yet is to switch upper/lowercase...
more feature to come, depending on your interests...
[attachment=2626]
edit : new vesion : key must be released, #pragma added
Let me know your feeling.
Best Regards,
* blinking cursor
Note
// vkb : virtual keyboard, by prime
// version 0.8 - 1st Oct 2015
// assigned on alpha-dot key
#pragma mode( separator(.,;) integer(b32) )
// forward decls (for main only)
drawkb();
drawtxt(txt);
chkkey();
addchar(c);
// main vars
local t:=150; // top pos kb
local f; // end req
local txt:=""; // text
local curs:=0; // cursor pos
// main prog
EXPORT vkb()
local c:=""; // char
f:=0;
txt:="";
curs=0;
drawkb();
REPEAT
drawtxt();
c:=chkkey();
if c≠"" then addchar(c); end;
UNTIL f;
IF f==1 THEN
RETURN(txt);
ELSE
RETURN (""); // cancelled
//--- keys
//decl
movecurs(d);
getmouse();
dropchar();
chkkey()
local k,m;
// keyboard chk
k:=GETKEY();
CASE
IF k==7 THEN // <-
movecurs(-1);
IF k==8 THEN // ->
movecurs(1);
IF k==19 THEN // del
dropchar();
IF k==30 THEN // ENTER
f:=1; // ends
IF k==4 THEN // esc
f:=2; // ends
IF k==49 THEN // spc
return (" ");
END; // case
if f THEN RETURN ""; END;
//mouse chk
m:=getmouse();
if m>0 then return CHAR(m+64); end;
RETURN "";
LOCAL r:=0; // release key
// get "key" from mouse
// return 1-26 for A-Z
getmouse()
local x:=MOUSE(0);
if x==-1 then r:=1; return 0; end; // no mouse activity
if x>270 then f:=1; r:=1; return 0; end; // tap ok
x:=IP(x/30);
IF r==0 THEN RETURN 0; END; // not released
r:=0; // pressed
local y:=MOUSE(1);
if y<150 then return 0; end; // out of scope
y:=IP((y-150)/30);
RETURN 1+x+(y*9);
// move cursor position
movecurs(d)
local n:=curs+d;
if n<0 then n:=0; end;
if n> DIM(txt) then n:=DIM(txt); end;
curs:=n;
//--- txt
// decl
txtwcurs(c); // add cusror to the txt
local alt:=0; // alternance
drawtxt()
rect_p(8,100,312,120,#AAAAAAh,#FFFFFFh);// clear txt
if alt==0 then
textout_p(txtwcurs(" "),10,100);
alt:=1;
else
textout_p(txtwcurs(CHAR(#25C1h)),10,100);
alt:=0;
end;
WAIT(0.13);
txtwcurs(c) // add cusror/char to the txt
local a:="";
local b:=MID(txt,1+curs);
if curs>0 then a:=LEFT(txt,curs); end;
if curs==DIM(txt) then b:=""; end;
RETURN a+c+b;
// add a char to the string
addchar(c)
txt:=txtwcurs(c);
// curs:=curs+1;
movecurs(1);
dropchar()
local a:="";
if curs>1 then a:=LEFT(txt,curs-1); end;
txt:=a+b;
movecurs(-1);
//--- kb
drawatpos(x,y,c); // decl
drawkb()
begin
local a;
rect_p(0,t,320,240);
for a from 0 TO 90 step 30 do
line_p(0,t+a,320,t+a);
end;
for a from 0 TO 270 step 30 do
line_p(a,t,a,240);
end;
for a from 0 TO 25 do
local x:=a MOD 9;
local y:= IP(a/9);
drawatpos(x,y,CHAR(65+a)); //65 up 97 lo
end;
drawatpos(7.9,2,"aA"); // switch up/lo
drawatpos(9,0,CHAR(#2713h)); //OK
//FREEZE;
end;
drawatpos(x,y,c)
begin
textout_p(c,G0,10+x*30,t+8+y*30);
end;
//--- key assignation : dot key on alpha
KEY KA_Dot
RETURN vkb();
KEY SKA_Dot
RETURN vkb();
[attachment=2626]
Best Regards,
