09-30-2015, 08:09 PM
Hey,
I just implemented my dream. Funny concept but quite useful in some cases.
This program allow you to call magnifying glass everywhere on calculator, it also can be called by opening its application. Look MGlassDemo.png in attached archive.
![[Image: cd5ef55b7523.png]](http://s018.radikal.ru/i513/1509/e7/cd5ef55b7523.png)
You press Shift-USER M (+/- key on keyboard) and glass appeared, you can drag and view anything better. Exit with On button (i promise graceful exit by ESC in next version).
Application's "MagnyGlass" program (don't forget to add images MGlass.png and MskGlass.png from archive to Files section of application):
Key callback code in MagnyGlassKey.hpprg:
EXPORT MagnyGlass()
LOCAL DX:=28; // center of glass offset X
LOCAL DY:=29; // offset Y
LOCAL X:=50; // Current center of glass position X
LOCAL Y:=50; // Y
LOCAL GW:=120; // Width of glass image
LOCAL GH:=76; // Height
LOCAL SW:=GROBW_P(G0); // Width of screen
LOCAL SH:=GROBH_P(G0); // Height of screen
DIMGROB_P(G1,SW,SH); // FOR SCREEN COPY
BLIT_P(G1,G0); // Save copy of screen
G2:=MagnyGlass.AFiles("MGlass.png"); // Load image of glass
G3:=MagnyGlass.AFiles("MskGlass.png"); // Load mask of glass
DIMGROB_P(G4,GW,GH); // prepare G4 GROB w size equal to glass image
DIMGROB_P(G5,GW,GH); // prepare G5 GROB w size equal to glass image
WHILE 1 DO // Never make such inf loops :-)
BLIT_P(G0,G1); // Restore image
BLIT_P(G4,G1,X-DX,Y-DY,X-DX+GW,Y-DY+GH); // Save normal (non-stretched) version under image
BLIT_P(G5,0,0,GW,GH,G1,X-15,Y-15,X+20,Y+15); // Save magnified version
BLIT_P(G5,G3,#0000FF); // Put red mask of glass on magnified version
BLIT_P(G0,X-DX,Y-DY,G5,#FF0000); // Put magnified version without (area inside glass)
BLIT_P(G0,X-DX,Y-DY,G2,#FF0000); // Put glass without red (draw glass over normal image and magnified part)
LOCAL msg:=WAIT(-1);
IF TYPE(msg)=6 THEN
IF msg(1)=0 OR msg(1)=1 THEN
X:=msg(2)-86+28; // shift to handle 86 (need to drag glass by handle instead of center) and return to center 28
Y:=msg(3)-56+29; // same for Y
BLIT_P(G0,G1); // Restore after inf loop (stupid idea).
START()
MagnyGlass();
KEY K_Neg()
MagnyGlass.MagnyGlass();
