09-20-2015, 11:22 PM
YouTube is exasperating at best. Lots of subtitles, but they don't show up on the video. Oh well, I will work on that but until then, here is an HP 25 Woodstock found with a dead ACT.
I replaced the original ACT with a PANAMATIK ACT which was then flashed with version 1.02 of the 67E Ir code. An Infrared led was installed in the HP 25 case sitting between the charger prongs of the calculator and the ACT was converted to the print version with the edition of two resistors and a transistor plus associated wiring.
After my presentation in Nashville the PDF of the Power Point will be found at the Panamatik site (thanks Bernhard).
Thanks of course go to Eric Smith and his emulator code.
enjoy the video. The program is in three parts:
Also of note is the
enjoy:
PANAMATIK ACT in HP 25.
how long did it take? check out the stopwatch display!
Geoff
- LBL A: load and print waypoints (lat and lon of associated plots on a map)
- LBL B: calculate great circle distance in nm and initial true track then print the results.
- LBL E: enter longitude found between initial longitude and destination longitude and calculate corresponding latitude and print result.
Also of note is the
- welcome screen: B777-300Er
- HP logo screen: HP 67e Ir
- stop watch to time the video!
enjoy:
Geoff
