09-17-2015, 07:28 PM
I guess I found a slight error in the geometry app. I added four random points and connected them to three segments. Doing some measurenemts I wanted to measure the angle of the segments.
So I added the angle feature and selected the points. I got my Prime usually set up in rad mode but using the geometry app I set it to degree mode.
The angle which was displayed after selecting the points was in rad, but it should be in degrees.
After switching to the apps menu and back to the geometry plot everyting was correct.
So to get the degrees I have to switch to the apps and back to the geometry app.
If I add a new angle all other angles will be displayed in rad again until I switch to the apps and then back to the geometry app.
Greetings
Greetings
