I am pleased to announce a new version of my
HP-15C Simulator for Windows, Linux and Mac OS X: Release 3.3.00, Build 5403.
It can be downloaded from the
simulator home page.
Thank you for the new version. Excellent work!
Namir
Torsten,
Great simulator indeed. I do have a question regarding internal accuracy of calculations. When I run the example in the
TVM program, I get the following:
Torsten HP-15C Simulator: 333,783.2505
Official HP-15C Emulator: 333,783.3508
Real HP-15C and HP-15 LE: 333,783.3508
Swiss Micro DM-15: 333,783.3508
Correct answer: 333,783.349948 (HP-30b, HP-19BII and HP-17BII)
What do you believe causes this discrepancy? Can it be identified and addressed in a subsequent release? I actually prefer the interface of your simulator over the official emulator (even if it is a bit slower).
Jeff
Mike,
My point is that the simulator is 'incorrect' by $0.10.
Jeff
Great tool and nice listings! Thank you very much!
# HEWLETT·PACKARD 15C Simulator program
# Created with version 3.3.00
000 { }
001 { 42 21 11 } f LBL A
002 { 43 11 } g x²
003 { 43 36 } g LSTx
004 { 40 } +
005 { 2 } 2
006 { 10 } ÷
007 { 43 32 } g RTN
Jeff,
I can not confirm your result of 333.783,2505 for my simulator.
I have tested it on Windows 7 64bit and XP 32bit. In both cases, I got the "correct" result of 333.783,3499484285. The simulator uses the full 17 digits available in IEEE format.
If "Strict HP-15C behaviour" is checked in the "Preferences", the result is the same as with the hardware models: 333.783,3508. In "strict mode", the precision is reduced to the 10 digits of the emulators using a copy of the original ROM.
Torsten
(01-20-2014 09:15 PM)Gerson W. Barbosa Wrote: [ -> ]Great tool and nice listings! Thank you very much!
Did you see the HTML export? It's even nicer ;-)
Torsten
(01-20-2014 09:24 PM)Torsten Wrote: [ -> ] (01-20-2014 09:15 PM)Gerson W. Barbosa Wrote: [ -> ]Great tool and nice listings! Thank you very much!
Torsten
Indeed!
And that's only the listing! Thanks again!
Gerson.
(01-20-2014 09:19 PM)Torsten Wrote: [ -> ]I can not confirm your result of 333.783,2505 for my simulator.
Torsten:
Thanks for your reply. I re-checked the program listing and it was accurate. I checked the "Strict HP-15C behaviour" and still it gave the same result: 333.783,2505. I was (or so I thought) meticulous in conducting the test the first time.
Then I verified the storage registers and 0.089633601 instead of '0' was found in register 3. I saved 0 in register 3 and it then gave the correct result. I will assume that I erred and I apologize for raising any concerns about your excellent simulator. It is a very impressive piece of work indeed. Not only that, it is even more accurate (in that it more closely matches the results of the financial calculators) when the "Strict HP-15C behaviour" is left unchecked.
Jeff
(01-20-2014 09:24 PM)Torsten Wrote: [ -> ]Did you see the HTML export? It's even nicer ;-)
Torsten
Is it me, or RollUp icon in HTML has rectangle after 'R' rather than an up arrow?
Great job otherwise, cheers!
Quote:Is it me, or RollUp icon in HTML has rectangle after 'R' rather than an up arrow?
This is a font issue. You do not have a font on your system, that has the character. I recommend to install the DejaVu Fonts. There are more details in the simulator help files under "Usage | Preferences | Font Settings".
Torsten
(01-21-2014 10:42 AM)Torsten Wrote: [ -> ]This is a font issue. You do not have a font on your system, that has the character. I recommend to install the DejaVu Fonts.
Torsten
Thanks a lot, it all works perfectly now.
Cheers,
Torsten,
I finally got a chance to spend some time using the simulator. Great work! Thank you.
Solver problem.
Corrected after Walter's findings.
EQN:
R*( TAN (ACOS (R/(R+h))) - ACOS(R/(R+h)) ) - dL/2 = 0
R= 6,371,000m (stored in register .0)
dL=1m (stored in register 0)
h=?
000 { }
002 { 45 40 48 0 } RCL ✛ .0
003 { 45 10 48 0 } RCL ÷ .0
004 { 15 } 1/x
005 { 43 24 } g COS-¹
006 { 25 } TAN
007 { 43 36 } g LSTx
008 { 30 } −
009 { 45 20 48 0 } RCL ✕ .0
010 { 45 30 0 } RCL − 0
011 { 43 32 } g RTN
RAD mode
Initial Guesses: 0, 1
Solve 'A' ->
Returns solver error unlike all HP calculators I have.
I realize this simulator uses different algorithm but never the less.
WP-34s also struggles at this.
I'm wondering if I'm doing something wrong.
I found interesting differences in answers given by: HP48G, HP35s and HP15c LE - real calculators and simulators: iPhone's 42S and Free15c. They all solve the case.
(01-24-2014 05:35 AM)RMollov Wrote: [ -> ]Solver problem.
EQN:
R(TAN (ACOS (R/(R+h)) - ACOS(R/(R+h))) - dL/2 = 0
R= 6,371,000m
dL=1m
h=?
RAD mode
BTW WP-34s also struggles at this.
I'm wandering if I'm doing something wrong.
I'm w
ondering if your EQN is wrong. I can simplify it to R(0) - dL/2 = 0 which doesn't include h anymore.
(01-24-2014 08:22 AM)walter b Wrote: [ -> ]I'm wondering if your EQN is wrong. I can simplify it to R(0) - dL/2 = 0 which doesn't include h anymore.
You're always correct, thank you for correcting my typos.
It should be:
R*( TAN(ACOS (R/(R+h))) - ACOS(R/(R+h)) ) - dL/2 = 0
Did I count the brackets properly this time?
I'll correct my original post accordingly.
The HP15c listing above is right though.
Shall I post the WP34s version, which also doesn't seem to work?
Very nice. Runs over 50 times faster on my Linux based computer than the HP-15C LE.
Hello RMollov,
which kind of problem do you describe?
h=?
The value of R looks like the earth radius for me. And as a not very well scaled problem.
Greetings
peacecalc
h=?
In register 0 the value dL/2 = 0.5 should be stored.
Quote:The value of R looks like the earth radius for me. And as a not very well scaled problem.
I guess it's the solution to a rope around the earth problem:
Take 3 of
Sweet & Short Math Challenges #15: April 1st Spring Special
