09-14-2015, 05:28 PM
I have been trying to use INPUT to input search strings for my Z EDITOR program.
But the Prime seems to parse some inputs without passing them straight to the user program.
For example, if you type in a single bracket, INPUT shows a pair. This happens whether you enter a bracket by using the () key, then cursor right and delete left. Or by using Shift/Chars and then selecting a single bracket.
Is there a way to avoid this, so that I could search for "WAIT(" for example, rather than "WAIT()" BUT NOT "WAIT(1"?.
EXPORT TRYIN()
LOCAL IN,TTL,LBL,HLP,RST,IVL;
PRINT();
IN:="";
TTL:="TRYING INPUT";
LBL:="INP";
HLP:="HLP";
RST:="";
IVL:="";
INPUT(IN,TTL,LBL,HLP,RST,IVL);
PRINT(IN);
PRINT(SIZE(IN));
PRINT(DIM(IN));
PRINT(ASC(IN));
//PRINT(STRING(IN));
//PRINT(QUOTE(EXPR(IN)));
WAIT;
