Here is Z EDITOR V0.3.
It drops the PRINT TERM FILE technology that i, at least, found problematic in V0.2.
Z EDITOR allows on-Prime searching and line numbering of Notes and Programs.
there is a programming bug: if you do two searches, you may see some results from your 1st search appended to the 2nd. Despite this, the program is useful for finding where your variables are used.
//ZED
//IDENT
LOCAL ZED:="Z EDITOR V0_3 ";
LOCAL CRID:=ZED+"© 2015 StephenG1CMZ";
LOCAL LF:=CHAR(10),SP:=" ";
// STR
LOCAL NWS:=" Not Working ";
LOCAL ESCS:="TAP Esc TO CONTINUE";
LOCAL ZFTYPS:={"ABOUT","INFO","HELP","Notes","Programs"};
LOCAL ACTIONS:={"ANALYZE","FIND_SEARCH","SEARCHALL","VIEW","SEND","REPLACE"};
LOCAL MECALL:=LF+"CONTACT StephenG1CMZ"+LF;
EXPORT ZSRCHD;
EXPORT ZSL;
EXPORT ZLL:={0};
EXPORT ZVL:={};
LOCAL ZFTYPN,ZFN;
LOCAL SRC,CNT;
BUSZY()
DRAWMENU("© 2015","G1CMZ","(BUSY)");
GRNTCK ()
TEXTOUT_P("✔",G0,0,0,0,#FF00h,100,#0h);
ANLZ (ZFNAME,TXT)
LOCAL CH,I;
BUSZY();
ZLL:={};
CNT:=1;
FOR I FROM 1 TO SIZE(TXT) DO
CH:=MID(TXT,I,1);
IF CH == LF THEN
CNT:=CNT+1;
ZLL(CNT):=I;
//ANLZ AND SEARCHALL(LF) DO
//A SIMILAR JOB
ANALYZE (ZFNAME,TXT,CNT)
LOCAL SZ:=SIZE(TXT);
LOCAL SZS:=ZFNAME+LF+SZ+" CHARS "+LF+2*SZ+" BYTES"+LF;
MSGBOX(SZS+CNT+" LINES"+LF,1);
LINES(P)
LOCAL LC:=0;
REPEAT
LC:=LC+1;
UNTIL ZLL(LC)≥P OR LC==SIZE(ZLL) ;
RETURN LC;
CHSLIN(ZSL)
LOCAL TTL:=SIZE(ZSL)+" FOUND";
LOCAL Q;
IF SIZE(ZSL)>0 THEN
CHOOSE(Q,TTL,ZSL);
ELSE //WA.CHOOSE
// 0 FOUND NEEDS NO TRANSLATION
MSGBOX(TTL,1);
VIEWER(ZFNAME,TXT) //NOT HP VIEW
LOCAL Z_EDITOR_VIEW:={};
LOCAL I,ST,LO,HI,SZ;
LOCAL FRAG:="NB: YOU MAY SEE OLD RESULTS APPENDED TO YOURS";
LOCAL SVS:="SEARCH BEFORE VIEWING PLEASE";
IF ZSRCHD THEN
MSGBOX(" EDITING"+NWS+LF+FRAG,1);
IF 1 THEN
//ALWAYS INCLUDE 1ST LINE
ST:=MID(TXT,1,ZLL(2));
ZVL(1):=ST;
FOR I:=1 TO SIZE(ZSL) DO
LO:=ZLL(ZSL(I));
IF (ZSL(I)+1)≤SIZE(ZLL) THEN
HI:=ZLL(ZSL(I)+1);
ELSE
HI:=SIZE(TXT);
SZ:=HI-LO;
// MSGBOX("LO"+LO+LF+"HI"+HI);
ST:=MID(TXT,LO,SZ);
// MSGBOX("ST"+ST);
// ZVL(I+1):=ST;
ZVL(I+1):={ZSL(I),ST}
Z_EDITOR_VIEW:=ZVL; //NICE NAME
EDITLIST(Z_EDITOR_VIEW);
ELSE
MSGBOX(SVS,1);
SEARCHONE(ZFNAME,TXT)
LOCAL TTL:=CRID;
LOCAL LBL:="FIND 1ST";
LOCAL HLP:=ZFNAME;
LOCAL IN:="";
LOCAL W,P;
LOCAL ZSL:={};
W:=INPUT(IN,TTL,LBL,HLP,"","");
IF W THEN
BUSZY(); // ZSRCHD:=1;
P:=INSTRING(TXT,IN);
IF P THEN
ZSL(1):=LINES(P)-1;
CHSLIN(ZSL);
SEARCHALL (ZFNAME,TXT)
LOCAL TTL:=CRID;
LOCAL LBL:="FIND ALL";
LOCAL HLP:=ZFNAME;
LOCAL IN:="";
LOCAL W,P,PREL;
LOCAL NFND;
IF W THEN
BUSZY(); ZSRCHD:=1;
// ANLZ(ZFNAME,TXT);
IF SIZE(IN)==0 THEN
IN:=LF; //AVOID MATCH ALL
P:=1;
ZSL:={}; NFND:=0;
REPEAT
PREL:=INSTRING(MID(TXT,P),IN);
IF PREL THEN
P:=P+PREL;
NFND:=NFND+1;
IF NFND==1 THEN
GRNTCK;
ZSL(NFND):=LINES(P-1)-1;
// MSGBOX(LINES(P-1));
ELSE
//PRINT("ZERO");
UNTIL PREL==0 OR P>SZ;
CHSLIN(ZSL);
ZSEND()
MSGBOX("CONNECTIVITY"+NWS+LF+MECALL+
"FOR SUPPORT");
ZREPL (ZFNAME,TXT)
MSGBOX(NWS);
DOACTN (Q,ZFNAME)
CASE
IF Q==1 THEN ANALYZE(ZFNAME,SRC,CNT) END;
IF Q==2 THEN SEARCHONE(ZFNAME,SRC) END;
IF Q==3 THEN SEARCHALL(ZFNAME,SRC) END;
IF Q==4 THEN VIEWER(ZFNAME,SRC) END;
IF Q==5 THEN ZSEND(); END;
IF Q==6 THEN ZREPL(ZFNAME,SRC); END;
//IF Q==2 THEN END;
DEFAULT
ZEDF(ZFTYPE,ZF)
LOCAL Q;
LOCAL ZFNAME:=ZFTYPE+"("+ZF+")";
LOCAL ZFD:=ZFNAME+SP+SIZE(EXPR(ZFNAME))+" BYTES";
// ANLZ EARLY
SRC:=EXPR(ZFNAME);
ANLZ(ZFNAME,SRC);
ZSRCHD:=0;
WHILE
CHOOSE(Q,ZFNAME,ACTIONS) DO
DOACTN(Q,ZFNAME);
ZEDCHSF(ZFTYPE)
LOCAL ZFILES:=EXPR(ZFTYPE);
LOCAL LBL:=SIZE(ZFILES)+SP+ZFTYPE;
IF SIZE(ZFILES)>0 THEN //WA.CHOOSE
WHILE
CHOOSE(ZFN,LBL,ZFILES) DO
ZEDF(ZFTYPE,STRING(ZFILES(ZFN)));
ELSE //WA.CHOOSE
MSGBOX(0+SP+ZFTYPE,1); //EMPTY DIR
ABOUT
LOCAL AS:="StephenG1CMZ is a software developer and systems tester. He would be happy to work to your requirements.";
LOCAL AZ:="Z EDITOR is StephenG1CMZ's first HP Prime program. ";
PRINT(); PRINT(CRID+LF);
PRINT(AS+LF+LF+AZ+LF+LF+ESCS)
WAIT;
INFO()
LOCAL LS:="Legal: No liability is accepted and in any event will be limited to the amount paid for this program.";
PRINT(LF+LS+LF+ESCS);
WAIT;
HELP()
LOCAL Q;
LOCAL SR:="Search: ✔==FOUND
To select all lines: search for Enter or OK.";
LOCAL VS:="Viewer:
you might find the line numbering of the text useful.
First search to populate the selected lines.";
LOCAL EAR:="Editing and Replacement:
Not implemented yet.";
LOCAL EV:= "Exported variables:
ZLL: list of line feeds.
ZSL: list of selected line numbers.
(Multiple matches on one line appear multiple times)";
LOCAL ISH:="known issues:
REFER TO FORUM FOR LATEST";
LOCAL TTL:="HELP";
LOCAL HLPSEL:={"TIPS","VARS","SUPPORT"};
WHILE CHOOSE(Q,TTL,HLPSEL) DO
PRINT(); PRINT(CRID);
CASE
IF Q==1 THEN
PRINT(SR+LF+VS+LF+EAR+LF);
IF Q==2 THEN
PRINT(EV+LF);
IF Q==3 THEN
PRINT(ISH+LF);
DEFAULT
PRINT(ESCS);
WAIT;
ZEDCHSFTYP()
LOCAL LBL:=CRID;
WHILE
CHOOSE(ZFTYPN,LBL,ZFTYPS) DO
CASE
IF ZFTYPN==1 THEN ABOUT() END;
IF ZFTYPN==2 THEN INFO() END;
IF ZFTYPN==3 THEN HELP() END;
DEFAULT
BUSZY();
ZEDCHSF(ZFTYPS(ZFTYPN));
ZEDDO()
ZEDCHSFTYP();
ZEDBYE()
LOCAL T:=LF+"THANKS FOR USING"+LF+ZED+LF;
LOCAL G:="BY StephenG1CMZ";
RETURN T+G;
EXPORT ZED_EDITOR()
ZEDDO();
RETURN ZEDBYE();
There is a problem with INPUT. some inputs are interpreted by the Prime. For example, if you ask for an opening bracket, INPUT gives you a pair. So you can search for WAIT(), for example, but not wait(1. Does anyone have a fix for this?
