09-05-2015, 08:38 PM
I've just finished adding a second 512KB FRAM chip to my FRAM-71. For anyone else doing this, here are some hints.
I made a first pass with a head mounted magnifiers and a fine tip on my soldering iron, but it wasn't working. I had to make a second pass at it this this afternoon. This time I used my DSLR with a macro lens and remote live view mode on my lap top screen to examine the results. Here is a snap of the setup. The FRAM-71 board was clamped in the vise where the solder braid is sitting.
[attachment=2497]
Here is a close up of the pin 6 repair. Used a small milling bit in a Dremel drill press to gain access to the buried pin.
[attachment=2498]
- The upper chip's pins must be bent somewhat more than 90ยบ to make contact with the lower chip's pins.
- Use bright lighting or you can't determine anything worth squat.
- Use magnification - very important!
- Flux is your friend - extremely important!
- Make sure your soldering iron tip hot enough to be able to melt solder quickly.
- Continuity test the results pin by pin.
- Don't break off pin 6. Had to do some field surgery on the chip. :-)
[attachment=2497]
[attachment=2498]
