Hi I have managed create the same function PART (TI89, HPPRIME) for HP48/49/50 calculators, this function to extract each part of an expression, very useful to analyze the algebraic expression, It requires that obj-> function is available in NEWRPL
sOURCE cODE
« 0 0 { } -> EXPRESSION XPART NPARTS OPERATOR OBJECTS
« EXPRESSION EVAL
IFERR OBJ->
THEN ->STR 'OPERATOR' STO 0 'NPARTS' STO OPERATOR 1 ->LIST 'OBJECTS' STO
ELSE ->STR 'OPERATOR' STO 'NPARTS' STO NPARTS ->LIST 'OBJECTS' STO NPARTS OPERATOR OBJECTS 3 ->LIST DROP
IF XPART NPARTS <= NOT
THEN "EXPRESSION " EXPRESSION + " CONTAINS ONLY " + NPARTS + " PARTS" + KILL
END
IF XPART 0 ==
THEN OPERATOR
ELSE
IF XPART -1 ==
THEN NPARTS
ELSE OBJECTS XPART GET
END
END
END
'PART' STO
Syntax:
part(Expr, Integer)
Returns the nth sub expression of an expression. If the second argument is empty (-1 for hp48/49/50), returns the number of parts.
If the second argument is ZERO, returns the operator if any, otherwise returns the same expression as string
Examples:
TI89/TIVOYAGE200PLT AND HPPRIME
part(sin(x)+cos(y)) → 2 // two parts sin(x) & cos(y)
part(sin(x)+cos(y),1) → sin(x) // first part
part(sin(x)+cos(y),2) → cos(y) // second part
part(sin(x)+cos(y),3) → "nonexistent part in the expression"
part(sin(x)+cos(y),0) → "+" // operator between parts
part( part(sin(x)+cos(y),1)) → 1 // number of parts of the first part
part( part(sin(x)+cos(y),2)) → 1 // number of parts of the second part
part( part(sin(x)+cos(y),1),1) → x // firts part of the firts part, sin(x)→ x
part( part(sin(x)+cos(y),2),1) → y // firts part of the second part, cos(y)→ y
part( part(sin(x)+cos(y),1),0) → "sin" // operator of the firts part, sin(x)→ "sin"
part( part(sin(x)+cos(y),2),0) → "cos" // operator of the second part, cos(x)→ "cos"
part(sin(x)) → 1 // one part
part(sin(x),1) → x // first part
part(sin(x),0) → "sin" // operator "sin"
part(part(exp(x)*sin(x) + cos(x),1),2) → sin(x) // second part of the first part exp(x)*sin(x) → sin(x)
part(part(exp(x)*sin(x) + cos(x),1),0) → "*" // operator of the first part exp(x)*sin(x) → "*"
part(part(exp(x)*sin(x) + cos(x),2),0) → "cos" // operator of the second part cos(x)→ "cos"
part(part(exp(x)*sin(x) + cos(x),2),1) → "x"
part(part(exp(x)*sin(x) + cos(x),1)) → 2
part(part(exp(x)*sin(x) + cos(x),1),1) → exp(x)
part(part(part(e^x*sin(x) + cos(x),1),1),1) → x
part(part(part(e^x*sin(x) + cos(x),1),1),0) → "exp"
special cases
part(-X) → 1 // one parts
part(-X,1) → 1 // firts part, X
part(-X,0) → 1 // operator "-"
part(X1) → 0 // No parts
part(X1,0) → "X1"
part(-1) → 0 // No parts
part(-X,0) → 1 // "-1"
hp48/49/50 SERIES
'sin(x)+cos(x))' -1 → 2 // 2 parts
'sin(x)+cos(x)' 0 → "+" // operator
'sin(x)+cos(x)' 1 → 'sin(x)' // part1
'sin(x)+cos(x)' 2 → 'cos(x)' // part2
'sin(x)+cos(x)' 3 → "nonexistent part in the expression"
application of the PART function
TI89 Code
difstep(f,x)
Func
//f(x),x
Local op
//diff(x,x)
If getType(f)="VAR"
Return when(f=x,1,0,0)
part(f,0)->op
//diff(k,x)
If part(f)=0
Return 0
//diff(f,x)
If op=""
Return 1*difstep(part(f,1),x)
//diff(x^n,x)
If op="^"
Return part(f,2)*part(f,1)^(part(f,2)-1)
//diff(v(x),x)
If op="sqroot"
Return 1/(2*sqroo(part(f,1)))
//diff(f+g,x)
If op="+"
Return difstep(part(f,1),x)+difstep(part(f,2),x)
//diff(f-g,x)
If op="-"
Return difstep(part(f,1),x)-difstep(part(f,2),x)
//diff(f*g,x)
If op="*"
Return part(f,1)*difstep(part(f,2),x)+part(f,2)*difstep(part(f,1),x)
//diff(f/g,x)
If op="/"
Return (part(f,2)*difstep(part(f,1),x)-part(f,1)*difstep(part(f,2),x))/part(f,2)^2
Return undef
EndFunc
