08-28-2015, 05:25 PM
08-28-2015, 05:41 PM
Bad
Boys
Boys
08-28-2015, 07:08 PM
(08-28-2015 05:41 PM)TASP Wrote: [ -> ]Bad
Boys
Not sure if a program is necessary. I've had this memorized for decades and seldom needed it since the 80's.
Black
Brown
Red
Orange
Yellow
Green
Blue
Violet
Gray
White
09-06-2015, 06:49 PM
(08-28-2015 05:25 PM)as5513482 Wrote: [ -> ]Is any program available for the resistors color code?
When I told my wife that if I see colors I see numbers, she said that I am crazy , so I gave it up.
09-06-2015, 07:07 PM
(09-06-2015 06:49 PM)TechAlex Wrote: [ -> ](08-28-2015 05:25 PM)as5513482 Wrote: [ -> ]Is any program available for the resistors color code?
Synesthesia?
09-07-2015, 02:50 AM
After thinking about this for a while, possibly at one time I had an HP41 keyboard overlay with the appropriate colors noted in flecks of electrical tape on the top rows. And there would have been a program with User mode key assignments that went along with it.
Considering my vague memory of it, I'm thinking I might have written the code during sparky school for a classmate to use in labs. If I had used it quite a bit I think I would have a clearer recollection.
My predilection to write 'bloatware' would make me think the program probably accepted gold and silver too and computed and displayed ranges of resistance possible for the colors.
I do remember using the colored electrical tape, an oatmeal container, and some conduit to make a 'gag' giant 10,000 watt 47K resistor for one of the instructors . . .
11-19-2015, 01:22 PM
(09-06-2015 06:49 PM)TechAlex Wrote: [ -> ]When I told my wife that if I see colors I see numbers, she said that I am crazy , so I gave it up.
http://xkcd.com/1604/
11-19-2015, 03:46 PM
I use the "program" in the attached picture.
It never fails :-)
It never fails :-)
11-19-2015, 04:27 PM
Etienne Victoria:
There have been updates to your "program." (For 5 and 6 band color codes).
11-20-2015, 12:51 PM
I don't know. Also I don't know about kneejerk reactions of others, but I would suggest you program one for your own. It is one of the most simplistic programs to do, where you just replace the color with a number and have 3 .. 5 meanings depending the place the color is. It doesn't need to be pretty, but fast to use.
Here is the one of the most advanced resistor programs ever invented. http://tower-freshmanphysics.wikispaces....de-all.gif You can use it to make your own for prime. Later you can extend the program to calculate series and parallel resistors based on E-series etc.
Only that it is much quicker to read them naturally than using converter, but I assume resistor color coding is losing its importance these days when everything starts to be surface mounted circuitry. ?
Later on one should note that the resistor with only resistance is the ideal (=school book) case, real world resistors have also reactance (resistor have inner capacitance/capacitor and inductance/coil in parallel depending the construction of it) making it reactive and introducing a frequency dependency for it. In other words calculations are made in complex domain when frequency dependancy is critical. Hopefully I translated the "tances" correctly.
11-20-2015, 02:09 PM
(11-19-2015 04:27 PM)DrD Wrote: [ -> ]Etienne Victoria:
You're right !! This is outright unacceptable !
I will demand a firmware update to the manufacturer ASAP :-)
Etienne
