08-25-2015, 12:14 AM
08-25-2015, 12:52 AM
(08-25-2015 12:14 AM)Gerson W. Barbosa Wrote: [ -> ]
R0 = 2048 Ω
R1 = R2 = R3 = ... = R512 = 163 Ω
Consider all components are ideal.
What should A, an 8-digit digital ammeter, read?
A = 1/(163/512 // 2048) = 3.1415926 amps
08-25-2015, 01:00 AM
(08-25-2015 12:52 AM)Dave Frederickson Wrote: [ -> ]A = 1/(163/512 // 2048) = 3.1415926 amps
That's correct!
08-25-2015, 02:21 AM
That was fun! Well not as much fun as typing "58008" on an LED calculator and reading it upside down, but fun neverless
08-25-2015, 03:20 AM
(08-25-2015 02:21 AM)Steve Simpkin Wrote: [ -> ]That was fun! Well not as much fun as typing "58008" on an LED calculator and reading it upside down, but fun neverless
Starting with 163*π ~ 512, I came up with
\[\frac{163+2^{20}}{163\times 2^{11}}\]
The rational approximation is interesting perhaps, as it involves two instances of the last Heegner number and two powers of two, but it is only good to eight places. So I thought the parallel circuit would be a little more interesting :-)
08-25-2015, 02:23 PM
What is the "//" symbol? Some of us aren't EE types...
08-25-2015, 02:59 PM
08-25-2015, 07:56 PM
(08-25-2015 02:59 PM)Gerson W. Barbosa Wrote: [ -> ]Same as || on the WP 34S:
a//b = (a*b)/(a + b)
Gerson.
Thanks Gerson!
08-25-2015, 11:04 PM
08-25-2015, 11:07 PM
Often overlooked, and I don't know why since this is what's happening: Add the conductances, then invert again to get resistance:
a // b = 1/ (1/a + 1/b)
To do several at once do for example (in HP-41 programming):
Doing it in complex numbers, it works for admittance too, ie, where there may be capacitive or inductive reactances.
100 \ First resistor value
1/X
330 \ Second resistor value
1/X
910 \ Third resistor value
1/X
[...] \ Go as far as you want.
1/X \ Turn the sum of the conductances into resistance.
08-25-2015, 11:26 PM
08-27-2015, 02:48 AM
(08-25-2015 11:07 PM)Garth Wilson Wrote: [ -> ]Often overlooked, and I don't know why since this is what's happening: Add the conductances, then invert again to get resistance:
I think the alternative form a // b = a*b/(a + b) was an easier option long ago, when these calculations were done by hand. Dividing 1 by a large number (more than two significant digits) was a cumbersome calculation to do manually, I remember. For this particular problem, i = 1/2048 + 512/163 might be better.
Gerson.
08-27-2015, 03:18 PM
Same theoretical reading using standard E24 resistors:
08-28-2015, 03:23 AM
I don't know what you mean by "E24" resistors, but we have:
3 / (15.06K // 183 // 1 // 24) = Pi A
ENTER
15060
1/X
183
1/X
24
1/X
1
1/X \ Not quite the most efficient,
/ \ but just to show what's done.
08-28-2015, 04:42 AM
For your amusement.
Parallel Resistor Calculator in Excel
Voltage Divider Calculator in Excel
The calculators use the E24 and E96 Standard EIA Decade Resistor Values.
Courtesy of Texas Instruments
Edit: I just realized I collect vintage TI calculators, too.
08-28-2015, 05:31 AM
(08-28-2015 03:23 AM)Garth Wilson Wrote: [ -> ]I don't know what you mean by "E24" resistors, but we have:
ENTER
15060
1/X
183
1/X
24
1/X
1
Likewise, 2 ENTER 20000 1/x 110 1/x + 10 1/x + 4 1/x + 1 + 1/x / = e A.
Parallel resistors values courtesy of Wolfram Alpha:
http://www.wolframalpha.com/input/?i=Egy...1000000000
I should have written "E24 series resistors", but since this involves resistors in parallel I thought this might be a bit confusing. Those E24 resistors are easily available, but I guess no one would want to build a physical circuit. Anyway, 5% tolerance would be too much for this application :-)
http://www.logwell.com/tech/components/r...alues.html
08-28-2015, 05:52 AM
(08-28-2015 04:42 AM)Dave Frederickson Wrote: [ -> ]Edit: I just realized I collect vintage TI calculators, too.
Only a TI-57 here, but I had a TI-51-III in 1982, replaced three months later by a TI-59 due to a faulty keyboard. The TI-59 worked flawlessly for about six months before eventually being stolen. The replacement HP-15C is still working to date :-)
08-28-2015, 01:47 PM
(08-28-2015 05:52 AM)Gerson W. Barbosa Wrote: [ -> ](08-28-2015 04:42 AM)Dave Frederickson Wrote: [ -> ]Edit: I just realized I collect vintage TI calculators, too.
I suspect others missed the joke, too. My calculators are the old Excel spreadsheet resistor calculators written by a guy at TI.
Dave
08-28-2015, 05:33 PM
(08-28-2015 01:47 PM)Dave Frederickson Wrote: [ -> ](08-28-2015 05:52 AM)Gerson W. Barbosa Wrote: [ -> ]Only a TI-57 here, but I had a TI-51-III in 1982, replaced three months later by a TI-59 due to a faulty keyboard. The TI-59 worked flawlessly for about six months before eventually being stolen. The replacement HP-15C is still working to date :-)
Quote:PARALLEL RESISTOR CALCULATOR, Version 1
By Bruce Carter, Texas Instruments Applications
This utility solves a common engineering problem - how to reach a target
resistance with two resistors in parallel. It assumes that you are free to choose
one of the two resistors that will be put in parallel - called the "seed" resistor.
The spreadsheet will then choose the closest resistor that, in parallel with
the seed resistor, will produce the target resistance. You have the choice of
using 1% resistors, or 5%.
I did follow the links and noticed the TI reference. I even wondered about the connection to TI calculators. Sarcasm sign needed here sometimes :-)
I usually solve the first problem on the WP 34S by following this procedure:
1000 ENTER 50 +/- g || --> -52.6315789474
Then I manually select one from the tables (or from my spare parts box), closest positive value, of course :-)
1000 ENTER 52.3 g || --> ~ 49.7 ohms.
Gerson.
P.S.: I love the || function on the WP-34S. Thanks, Walter!
11-04-2015, 01:57 AM
Here is simple program (I just typed) in UserRPL to make it easy with 28..50g. The original idea is from L.R.Linares (He have done really nice series of HP49/HP50g instruction videos to youtube), but I'm not sure if this is 1:1 his solution for this job or were it even Linares original idea at first place.
I named it Parallel Impedance, Pimp for short.
For imaginary circuit
First enter two first parallel impedance values (in complex, s-domain, resistance form) in input line like:
Z2 [SPaCe] Z3
Pimp
=> 1/(1/Z2)+(1/Z3)
Z1 +
=> (1/(1/Z2)+(1/Z3))+Z1
Z4 Pimp
=> 1/(1/((1/(1/Z2)+(1/Z3))+Z1))+(1/Z4) <-- Parentheses look out..
That is it, now only should one use ->num etc. to get decimal form.
-Middle of night, -LV
INV SWAP INV SWAP + INV
Z1
# Z4 # Z3 # Z2
Z2 [SPaCe] Z3
Pimp
=> 1/(1/Z2)+(1/Z3)
Z1 +
Z4 Pimp
