08-23-2015, 02:40 AM
This program will evaluate a formula stored in subroutine 99 for the definite integral using the Trapezoidal rule.
EXAMPLE
1. Enter the main program listed below
2. Enter a formula into subroutine 99. A routine to evaluate the formula sin(x)/ln(x) would look like this:
Lbl 99
Input
Sin
Swap
Ln
RTN
3. Enter the lower, then the upper limit of integration. To evaluate sin(x)/ln(x) at the limits 1.2 and 10 (lower limit 1st):
1.2
Input
10
Input
4. Run the program- shift key+ Prgm, use the up/down arrow keys to select the proper program, and press =
It takes about 15 seconds to calculate simple integrals. Accuracy can be increased as noted below, but calculation time will also increase.
[attachment=2471]
MAIN PROGRAM LISTING (comments start with //):
Intergrat //enter this using the MSG command
STO 1 //store the lower and higher limits of integration
Swap
STO 2
- //the span (low, high) is divided up by the number of partitions
1
EEX
3 //1000 partitions. Increasing # of partitions will increase accuracy
STO 2
0
STO 5 //zero out storage register 5
RCL 0
Call 99 //evaluate the function at X1
STO 3 //result= XY1
Lbl 50
RCL 0
RCL 2 //h increment
STO 0 //next X1
Call 99 //evaluate function at X2
STO 4 //XY2
RCL 3 //XY1
+ //take the average
2
RCL 2 //calculate the area
STO +5 //add to area
RCL 4 //XY2 becomes-
STO 3 //XY1
RCL 0 //reached upper limit?
RCL 1
GT50
RCL 5 //display definite integral
Stop
EXAMPLE
Lbl 99
Input
Sin
Swap
Ln
RTN
1.2
Input
10
Input
[attachment=2471]
Swap
STO 2
1
EEX
STO 2
0
RCL 0
STO 3 //result= XY1
Lbl 50
RCL 0
RCL 2 //h increment
STO 0 //next X1
STO 4 //XY2
RCL 3 //XY1
2
STO 3 //XY1
RCL 1
GT50
Stop
