How would you efficiently replace a column vector of a matrix, with another column vector, of suitable dimension?
Example: a:=[[−1,5],[2,5]];
replace column 2 with [3 4] ==> [[−1,3],[2,4]]
Ideally, the same approach will work in HOME or CAS.
This seems to work in cas and home on the emulator:
#cas
replacecol(matrix,vector,col):=
local a;
a:=DELCOL(matrix,col);
return ADDCOL(a,vector,col);
#end
(08-22-2015 03:02 PM)roadrunner Wrote: [ -> ]This seems to work in cas and home on the emulator:
[code]#cas
thank you, Road, this' helpful also for me!
simple enough
ciao
Salvo
In HOME only, Mat[-Column]:=vector will do it in one go... Mat[-column] will return a column.
cyrille
The responses provided reveal many of the shortcoming's in Prime's ability to deal with matrices. The burden of column replacement using support functions such as DELCOL(), ADDCOL(), and REPLACE(), make difficult what should be quite a simple operation.
The so-called, "dichotomy," HOME vs. CAS, renders useless, what COULD be a useful solution to this problem: Mat[-Column]:=vector, when matrices contain symbolic entries. Negative indices are not supported in CAS.
For example, replacing column 2 of matrix a, with vector b, isn't supported in HOME mode, even by using Mat[-Column]:=vector, when:
a:=[[x2,-x1],[x3,-x2],[x3,-x4]]; // Symbolic entries not allowed in HOME
b:=[[-x1],[-x2],[-x1]];
My original post attempts to emphasize the current weakness, (and encourage further development), in matrix handling methods; within 'both' sides of the HOME / CAS status quo. Understandably, the Primes's authors have much to do, as the Prime undergoes evolution. May I request that improvement in matrix handling be added to "the list?"
Thanks!
-Dale-
So out of curiosity, what is the 50g sequence for doing this? I remember from long before my HP time trying to do a similar thing on the 48 series was pretty painful too.
Quote:what is the 50g sequence for doing this
matrix
column
COL-
DROP
vector
column
COL+
is one way
Personally, I would prefer to see an external compiler/debugger so just the compiled programs can be stored on the handheld and the source code can remain on my PC.
Presumably, with large amounts of requests and limited resources, HP will decide which requests to work on based on what they think will sell the most calculators.
(08-24-2015 02:47 PM)Tim Wessman Wrote: [ -> ]So out of curiosity, what is the 50g sequence for doing this? I remember from long before my HP time trying to do a similar thing on the 48 series was pretty painful too.
I think these two progs do the job
Stack:
Mat
Vec
R/C Number
V2C, Vector to Column
« 1 SWAP 2 ->LIST
SWAP TRN REPL
V2R, Vector to Row
« 1 2 ->LIST SWAP
REPL
