Tried to use the spreadsheet for something yesterday and the first thing I test, reboots the calculator and all the input is lost...
http://screencast.com/t/9lqgYY0nqW
It seems to be related with the NAME. The virtual calculator also crashes.
Couldn't reproduce with my first try here, but on the list to look at.
I tried your second example on the emulator, first with no digit-grouping, worked without problems. Then I used your grouping: "1.000,05" as I thought it was another fault caused by that, but it worked, too. I played a little bit using the named fields and suddenly: crash. After that I reset to no digit-grouping, entered your example and played around, no crash. So my first impression seems to be correct, another bug caused by digit-grouping set to some other value.
Arno
The spreadsheet contents for name "AAA" are corrupt which crashes the app. The name "CCC" seems to be ok, on my machine. Seems to be a problem with cell names in the spreadsheet app.
(08-19-2015 11:21 AM)DrD Wrote: [ -> ]The spreadsheet contents for name "AAA" are corrupt which crashes the app. The name "CCC" seems to be ok, on my machine. Seems to be a problem with cell names in the spreadsheet app.
Weird, I thought to try that again and used "better" names, did not crash. Then I renamed the fields to AAA and CCC and played around with different formulas using these and no crash. Hmmm...
Arno
