01-28-2015, 08:08 PM
**Update No. 2**
Yet another version, this time with local registers and DST correction built in. (Thanks and credit to Dieter for the DST code.) DST settings are for the US, DST beginning on the second Sunday in March and ending on the first Sunday in November.
If you prefer manual DST, remove steps 4 through 22 and subroutine 01 which begins at step 224. You may then manually set flag A for DST. It will be cleared after each use - if you prefer to stay in DST mode for a series of calculations, change the "FS?C A" in step 34 to simply "FS? A."
If you don't want to use local registers, just remove the LocR16 command and the "." in front of each register number
Operation is essentially as described for the first versions. Here is a dat file for the emulator. [attachment=1502]
(I removed the dat file below for the original version.)
Sunrise/Sunset Program:
Registers:
**See below for an update**
Below are three versions of a program for the wp34s to calculate sunrise and sunset times. The programs are based on programs that I got from Marwan Joury, versions of which he posted in this article. I give total credit to Marwan, all I did was port his work to the wp34s. Most of the comments in my program listings are from Marwan's original listings that he sent to me. (So if you have any questions regarding the meat of the program, you will have to ask Marwan...)
Program operation is as follows:
Replace steps 6 and 7 with your offset from UTC, West is negative. (You must manually account for Daylight Saving Time, or British Summer Time, or whatever your local flavor of seasonally shifting daylight hours to suit local custom is called if you have one.)
Key in your latitude in steps 15 through 22 in decimal degrees, North is positive.
Key in your longitude in steps 24 through 32 in decimal degrees, West is negative. (You may use as many digits as you want for longitude and latitude, there is no requirement for 5 digits past the decimal point.)
Go to run mode, key in the date in which you are interested in yyyy.mmdd format for version 1, dd.mmyyyy format for version 2 or mm.ddyyyy format for version 3. Press XEQ 'RS'. The program will run, briefly display "Rise-Set", then stop with the sunrise time displayed in the dot-matrix display area, and the sunset time displayed in the numerical display, in 24 hour clock format. Press R/S if you want see the day length. The sunrise and sunset times will still be on the stack in Z and Y, respectively, if you want to look at them again. All returned values are in hh.mmss format.
Since your location information is hard-coded into the program, after entering the data as a part of the program, you can just run the program for new dates until and unless you want to change the location.
You may also replace the value stored in register 6 (steps 8 through 12, which is the angle from zenith being calculated) with other values, for example 96, 102 or 108 degrees to calculate civil, nautical and astronomical twilight times, respectively. If you enter a value less than 90 degrees, you may calculate the times at which the sun rises above and then later sets below 90 minus that value. (E.g., if you enter 50 degrees, the program will calculate the times at which the sun rises to and sets below 40 degrees elevation. This may be useful if you desire to limit your exposure to UV, for example.)
One of the subroutines may be used as a stand-alone program to calculate the number of days between two dates. Key in a date, press enter, key in other date, then press XEQ 02. (Key in the later date first if you want a positive result.)
Attached below is a wp34s emulator dat file that has the y.md version. The differences between the programs are fairly trivial, so you can easily edit to create the d.my or m.dy versions. (Changes are in step 2, and between steps 78 to 86.) If you have a crystal installed in your real wp34s (to facilitate reliable communication), and a communication cable, you can place the dat file in the appropriate folder, start the emulator, and upload to your real wp34s to save a lot of manual keying.
Version 1 - Input date in yyyy.mmdd format
Version 2 - Input date in dd.mmyyyy format
Version 3 - Input date in mm.ddyyyy format
Register Usage:
**Update No. 1**
Based on Paul's and Dieter's ideas below, here is a single new version that will work in any date mode. (You must of course know what date mode the calculator is set to and enter the date accordingly.) I eliminated the accessible subroutine to calculate days between dates, since the built in wp34s ΔDAYS function can be used for that. The single program is now only 206 steps. The steps where time zone, longitude and latitude are enter have changed from above, but those are easy to figure. Otherwise, data entry, operation, and register usage remain the same, except 24 is no longer stored in register 20. I will change the wp34s.dat file to this version when I get the chance.
Step Instruction Comments
001 LBL 'RS'
002 LocR 016 allocate 16 local registers
003 DEG Set degrees mode (used throughout)
004 STO .00 store input date
005 YEAR get year of input date
006 FILL fill stack
007 #011 enter 11, for November
008 XEQ 01 calculate j-day for last Sunday in October
009 #007 enter 7
010 + add 7 for US DST end 1st Sunday in November
011 x<>Y get year of input date back
012 #003 enter 3, for March
013 XEQ 01 calculate j-day for last Sunday in February
014 #014 enter 14
015 + add 14 for US DST start 2nd Sunday in March
016 RCL .00 recall input date
017 D→J get j-day of input date
018 SF A set DST flag
019 x≥? Y IF date < first DST day
020 x≥? Z OR date ≥ first standard time day
021 CF A THEN clear DST flag
022 RCL .00 Recall input date
023 ENTER Copy input date into Y, could use RCL X, etc.
024 YEAR year of input date
025 DEC X previous year
026 #12 enter 12
027 #31 enter 31
028 →DATE create last day of previous year in current date mode.
029 X<>Y
030 ΔDAYS days from beginning of year
031 STO .04
032 5 Offset from UTC (-5 represents EST)
033 +/- Offset from UTC (-5 represents EST)
034 FS?C A If flag A set, DST in effect for input date
035 INC X If flag A set, increment offset from UTC
036 STO .03 Local time offset from UTC
037 9
038 0
039 .
040 5
041 ->HR 90.83333333333333 entered for degrees from zenith at
Sunrise/sunset (fewer steps than direct entry)
042 STO .05 degrees from zenith for Sunrise. May be changed if
twilight times or other solar elevation times are desired (e.g.
enter 50 to find times when sun is at 40 degrees altitude.)
043 3 Latitude
044 5 Latitude
045 . Latitude
046 1 Latitude
047 2 Latitude
048 3 Latitude
049 4 Latitude
050 5 Latitude
051 STO .01 35.12345 for example (decimal)
052 9 Longitude
053 0 Longitude
054 . Longitude
055 5 Longitude
056 4 Longitude
057 3 Longitude
058 2 Longitude
059 1 Longitude
060 +/- Longitude
061 STO .02 -90.54321 for example (decimal)
062 #015 15 Degrees per hour
063 STO .09 Store for later use
064 /
065 STO .06 Longitude hour value (lngHour)
066 #018
067 XEQ 05 Calculate approximate time for sunset
068 XEQ 06
069 STO .13 Done calculating sunset. Store the result
070 6 Calculate sunrise
071 XEQ 05
072 RCL .14 Recall 360
073 RCL- Y
074 XEQ 06
075 RCL .13 Recall sunset. Push sunrise to Y.
076 CL alpha clear alpha register for new text message
077 'Ris'
078 'e-S'
079 'et'
080 VIEWa Display text
081 PSE 25
082 CL alpha clear alpha register for new text message
083 alphaRC# Y copy Y register value to alpha register
084 VWalpha+ X view alpha (sunrise) in dot-matrix, sunset time in X register.
085 STOP
086 CPX STO Z store sunrise and sunset times in Z and T
087 x<>Y
088 H.MS- subtract sunrise from sunset for day length
089 CL alpha
090 'Day'
091 ' Le'
092 'ngt'
093 'h'
094 VWa+ X Display text and day length
095 RTN done
096 LBL 05 Subroutine for large common section
097 RCL- .06
098 #024 enter 24
099 /
100 RCL+ .04
101 STO .07 Approximate sunset time
102 .
103 9
104 8
105 5
106 6 enter 0.9856
107 x
108 3
109 .
110 2
111 8
112 9 enter 3.289
113 -
114 STO .08 Sun's mean anomaly
115 SIN Calculate sun's true longitude
116 1
117 .
118 9
119 1
120 6 enter 1.916
121 x
122 RCL+ .08
123 2
124 RCLx .08
125 SIN
126 #002
127 SDR 002 enter 0.02
128 x
129 +
130 3
131 RCLx .08
132 SIN
133 3
134 SDR 004 enter 0.0003
135 x
136 +
137 2
138 8
139 2
140 .
141 6
142 3
143 4 enter 282.634
144 +
145 #36
146 SDL 001 enter 360
147 STO .14
148 MOD
149 STO .08 Sun's true longitude
150 TAN Calculate sun's Right Ascension
151 .
152 9
153 1
154 7
155 6
156 4 enter 0.91764
157 x
158 ATAN
159 RCL .14 enter 360
160 MOD
161 STO .10 Sun's Right Ascension
162 RCL .08
163 #090 enter 90
164 STO .15 Store for later use
165 /
166 FLOOR
167 RCLx .15 Recall 90 and multiply
168 +
169 RCL .10
170 RCL/ .15 Recall 90 and divide
171 FLOOR
172 RCLx .15 Recall 90 and multiply
173 -
174 RCL/ .09 Recall 15 and divide
175 STO .10 Sun's Right Ascension converted into hours
176 RCL .08
177 SIN
178 .
179 3
180 9
181 7
182 8
183 2 enter 0.39782
184 x
185 STO .11 sinDec for sunset
186 ASIN
187 COS
188 STO .12 cosDec for sunset
189 RCL .05
190 COS
191 RCL .01
192 SIN
193 RCLx .11
194 -
195 RCL .01
196 COS
197 RCLx .12
198 / Sun's local Hour Angle (cosH)
199 ACOS
200 RTN
201 LBL 06 Subroutine for another common section
202 RCL/ .09 Recall 15 and divide
203 RCL+ .10
204 .
205 0
206 6
207 5
208 7
209 1 enter 0.06571
210 RCLx .07
211 -
212 6
213 .
214 6
215 2
216 2 enter 6.622
217 -
218 #024 enter 24
219 MOD
220 RCL- .06
221 RCL+ .03
222 ->H.MS
223 RTN
224 LBL 01 Subroutine to calculate last Sunday of prior month.
225 #001
226 →DATE = 1 March resp. 1 November
227 D→J
228 #007
229 IDIV
230 RCLx L Monday on or before 1 March resp. 1 November
231 DEC X last Sunday of February resp. October
232 END
Registers:
Register Use/contents
.00 Input date
.01 latitude
.02 longitude
.04 day number of year
.08 Sun's mean anomaly/Sun's true longitude
.09 15 degrees per hour
.10 Sun's Right Ascension/right ascension converted to hours
.13 sunset time
.14 360
.15 90
001 LBL 'RS'
002 y.md set date mode
004 XEQ 01 Get days since first of year
005 STO 05
006 5 Offest from UTC (-5 represents EST)
007 +/- Offest from UTC (-5 represents EST)
008 STO 03 Local time offset from UTC
009 9
010 0
011 .
012 5
013 ->HR 90.83333333333333 entered for degrees from zenith
at Sunrise/sunset (fewer steps than direct entry)
014 STO 06 degrees from zenith for Sunrise. May be changed if
015 3 Latitude
016 5 Latitude
017 . Latitude
018 1 Latitude
019 2 Latitude
020 3 Latitude
021 4 Latitude
022 5 Latitude
023 STO 01 35.12345 for example (decimal)
024 9 Longitude
025 5 Longitude
026 . Longitude
027 5 Longitude
028 4 Longitude
029 3 Longitude
030 2 Longitude
031 1 Longitude
032 +/- Longitude
033 STO 02 -95.54321 for example (decimal)
034 1 15 Degrees per hour
035 5 15 Degrees per hour
036 STO 19 Store for later use
037 /
038 STO 07 Longitude hour value (lngHour)
039 1
040 8 Calculate approximate time for sunset
041 XEQ 05
042 XEQ 06
043 STO 15 Done calculating sunset. Store the result
044 6 Calculate sunrise
045 XEQ 05
046 RCL 17 Recall 360
047 X<>Y
048 -
049 XEQ 06
050 RCL 15 Recall sunset. Push sunrise to Y.
051 CL alpha clear alpha register for new text message
052 'Ris'
053 'e-S'
054 'et'
055 VIEWa Display text
056 PSE 25
057 CL alpha clear alpha register for new text message
058 alphaRC# Y copy Y register value to alpha register
059 VWalpha+ X view alpha (sunrise) in dot-matrix, sunset time in X register.
060 STOP
061 CPX STO Z store sunrise and sunset times in Z and T
062 ->HR convert sunrise time to decimal hours
063 x<>y swap x and y
064 ->HR convert sunset time to decimal hours
065 - subtract for decimal hour day length
066 ->H.MS convert day length to HMS
067 CL alpha
068 'Day'
069 ' Le'
070 'ngt'
071 'h'
072 VWa+ X Display text and day length
073 RTN done
074 LBL 01 Calculate day of year given date
075 ENTER
076 YEAR
077 DEC X
078 .
079 1
080 2
081 3
082 1
083 +
084 LBL 02 Given two dates (on stack) get days between
085 y.md set date mode for delta-day entry point
086 D->J julian day no. of input date
087 X<>Y
088 D->J julian day no. of last day of previous year
089 RCL- Y days since first of year (or between dates)
090 RTN
091 LBL 05 Subroutine for large common section
092 RCL- 07
093 2
094 4 enter 24
095 STO 20 Store for later use
096 /
097 RCL+ 05
098 STO 08 Approximate sunset time
099 .
100 9
101 8
102 5
103 6 enter 0.9856
104 x
105 3
106 .
107 2
108 8
109 9 enter 3.289
110 -
111 STO 09 Sun's mean anomaly
112 SIN Calculate sun's true longitude
113 1
114 .
115 9
116 1
117 6 enter 1.916
118 x
119 RCL+ 09
120 2
121 RCLx 09
122 SIN
123 .
124 0
125 2 enter 0.02
126 x
127 +
128 3
129 RCLx 09
130 SIN
131 .
132 0
133 0
134 0
135 3 enter 0.0003
136 x
137 +
138 2
139 8
140 2
141 .
142 6
143 3
144 4 enter 282.634
145 +
146 3
147 6
148 0 enter 360
149 STO 17
150 MOD
151 STO 10 Sun's true longitude
152 TAN Calculate sun's Right Ascension
153 .
154 9
155 1
156 7
157 6
158 4 enter 0.91764
159 x
160 ATAN
161 RCL 17 enter 360
162 MOD
163 STO 11 Sun's Right Ascension
164 RCL 10
165 9
166 0 enter 90
167 STO 18 Store for later use
168 /
169 FLOOR
170 RCLx 18 Recall 90 and multiply
171 +
172 RCL 11
173 RCL/ 18 Recall 90 and divide
174 FLOOR
175 RCLx 18 Recall 90 and multiply
176 -
177 RCL/ 19 Recall 15 and divide
178 STO 11 Sun's Right Ascension converted into hours
179 RCL 10
180 SIN
181 .
182 3
183 9
184 7
185 8
186 2 enter 0.39782
187 x
188 STO 12 sinDec for sunset
189 ASIN
190 COS
191 STO 13 cosDec for sunset
192 RCL 06
193 COS
194 RCL 01
195 SIN
196 RCLx 12
197 -
198 RCL 01
199 COS
200 RCLx 13
201 / Sun's local Hour Angle (cosH)
202 ACOS
203 RTN
204 LBL 06
205 RCL/ 19 Recall 19 and divide
206 RCL+ 11
207 .
208 0
209 6
210 5
211 7
212 1 enter 0.06571
213 RCLx 08
214 -
215 6
216 .
217 6
218 2
219 2 enter 6.622
220 -
221 RCL 20 Recall 24
222 MOD
223 RCL- 07
224 RCL+ 03
225 ->H.MS
226 END
001 LBL 'RS'
002 d.my set date mode
005 STO 05
009 9
010 0
011 .
012 5
twilight times or other solar elevation times are desired (e.g. enter
015 3 Latitude
016 5 Latitude
017 . Latitude
018 1 Latitude
019 2 Latitude
020 3 Latitude
021 4 Latitude
022 5 Latitude
024 9 Longitude
025 5 Longitude
026 . Longitude
027 5 Longitude
028 4 Longitude
029 3 Longitude
030 2 Longitude
031 1 Longitude
032 +/- Longitude
037 /
039 1
041 XEQ 05
042 XEQ 06
045 XEQ 05
047 X<>Y
048 -
049 XEQ 06
052 'Ris'
053 'e-S'
054 'et'
056 PSE 25
060 STOP
067 CL alpha
068 'Day'
069 ' Le'
070 'ngt'
071 'h'
073 RTN done
075 ENTER
076 YEAR
077 DEC X
078 SDR 6
079 3
080 1
081 .
082 1
083 2
084 +
085 LBL 02 Given two dates (on stack) get days between
086 d.my set date mode for delta-day entry point
087 D->J julian day no. of input date
088 X<>Y
089 D->J julian day no. of last day of previous year
090 RCL- Y days since first of year (or between dates)
091 RTN
092 LBL 05 Subroutine for large common section
093 RCL- 07
094 2
095 4 enter 24
096 STO 20 Store for later use
097 /
098 RCL+ 05
099 STO 08 Approximate sunset time
100 .
101 9
102 8
103 5
104 6 enter 0.9856
105 x
106 3
107 .
108 2
109 8
110 9 enter 3.289
111 -
112 STO 09 Sun's mean anomaly
113 SIN Calculate sun's true longitude
114 1
115 .
116 9
117 1
118 6 enter 1.916
119 x
120 RCL+ 09
121 2
122 RCLx 09
123 SIN
124 .
125 0
126 2 enter 0.02
127 x
128 +
129 3
130 RCLx 09
131 SIN
132 .
133 0
134 0
135 0
136 3 enter 0.0003
137 x
138 +
139 2
140 8
141 2
142 .
143 6
144 3
145 4 enter 282.634
146 +
147 3
148 6
149 0 enter 360
150 STO 17
151 MOD
152 STO 10 Sun's true longitude
153 TAN Calculate sun's Right Ascension
154 .
155 9
156 1
157 7
158 6
159 4 enter 0.91764
160 x
161 ATAN
162 RCL 17 enter 360
163 MOD
164 STO 11 Sun's Right Ascension
165 RCL 10
166 9
167 0 enter 90
168 STO 18 Store for later use
169 /
170 FLOOR
171 RCLx 18 Recall 90 and multiply
172 +
173 RCL 11
174 RCL/ 18 Recall 90 and divide
175 FLOOR
176 RCLx 18 Recall 90 and multiply
177 -
178 RCL/ 19 Recall 15 and divide
179 STO 11 Sun's Right Ascension converted into hours
180 RCL 10
181 SIN
182 .
183 3
184 9
185 7
186 8
187 2 enter 0.39782
188 x
189 STO 12 sinDec for sunset
190 ASIN
191 COS
192 STO 13 cosDec for sunset
193 RCL 06
194 COS
195 RCL 01
196 SIN
197 RCLx 12
198 -
199 RCL 01
200 COS
201 RCLx 13
202 / Sun's local Hour Angle (cosH)
203 ACOS
204 RTN
205 LBL 06
206 RCL/ 19 Recall 19 and divide
207 RCL+ 11
208 .
209 0
210 6
211 5
212 7
213 1 enter 0.06571
214 RCLx 08
215 -
216 6
217 .
218 6
219 2
220 2 enter 6.622
221 -
222 RCL 20 Recall 24
223 MOD
224 RCL- 07
225 RCL+ 03
226 ->H.MS
227 END
001 LBL 'RS'
002 m.dy set date mode
005 STO 05
009 9
010 0
011 .
012 5
015 3 Latitude
016 5 Latitude
017 . Latitude
018 1 Latitude
019 2 Latitude
020 3 Latitude
021 4 Latitude
022 5 Latitude
024 9 Longitude
025 5 Longitude
026 . Longitude
027 5 Longitude
028 4 Longitude
029 3 Longitude
030 2 Longitude
031 1 Longitude
032 +/- Longitude
037 /
039 1
041 XEQ 05
042 XEQ 06
045 XEQ 05
047 X<>Y
048 -
049 XEQ 06
052 'Ris'
053 'e-S'
054 'et'
056 PSE 25
060 STOP
067 CL alpha
068 'Day'
069 ' Le'
070 'ngt'
071 'h'
073 RTN done
075 ENTER
076 YEAR
077 DEC X
078 SDR 6
079 1
080 2
081 .
082 3
083 1
084 +
086 m.dy set date mode for delta-day entry point
088 X<>Y
091 RTN
093 RCL- 07
094 2
095 4 enter 24
097 /
098 RCL+ 05
100 .
101 9
102 8
103 5
104 6 enter 0.9856
105 x
106 3
107 .
108 2
109 8
110 9 enter 3.289
111 -
114 1
115 .
116 9
117 1
118 6 enter 1.916
119 x
120 RCL+ 09
121 2
122 RCLx 09
123 SIN
124 .
125 0
126 2 enter 0.02
127 x
128 +
129 3
130 RCLx 09
131 SIN
132 .
133 0
134 0
135 0
136 3 enter 0.0003
137 x
138 +
139 2
140 8
141 2
142 .
143 6
144 3
145 4 enter 282.634
146 +
147 3
148 6
149 0 enter 360
150 STO 17
151 MOD
154 .
155 9
156 1
157 7
158 6
159 4 enter 0.91764
160 x
161 ATAN
163 MOD
165 RCL 10
166 9
167 0 enter 90
169 /
170 FLOOR
172 +
173 RCL 11
175 FLOOR
177 -
180 RCL 10
181 SIN
182 .
183 3
184 9
185 7
186 8
187 2 enter 0.39782
188 x
190 ASIN
191 COS
193 RCL 06
194 COS
195 RCL 01
196 SIN
197 RCLx 12
198 -
199 RCL 01
200 COS
201 RCLx 13
203 ACOS
204 RTN
205 LBL 06
207 RCL+ 11
208 .
209 0
210 6
211 5
212 7
213 1 enter 0.06571
214 RCLx 08
215 -
216 6
217 .
218 6
219 2
220 2 enter 6.622
221 -
223 MOD
224 RCL- 07
225 RCL+ 03
226 ->H.MS
227 END
Register Usage:
01 Latitude
02 Longitude
03 Offset from UTC (local time)
04 Date
05 Days from the beginning of the year.
06 Zenith
07 Longitude -> Hour Angle (lngHour)
08 Approximate time (t)
09 Sun's mean anomaly (M)
10 Sun's true longitude (L)
11 Right Ascension (RA)
12 Sun's declination (sinDec)
13 Sun's declination (cosDec)
14 Sun's local hour angle (H)
15 Sunset time
16 Year value
17 360
18 90
19 15
20 24
21 0.06571
22 6.622
**Update No. 1**
001 LBL 'RS'
002 DEG Set degrees mode (used throughout)
003 ENTER Copy input date into Y, could use RCL X
004 YEAR year of input date
005 DEC X previous year
006 #12 enter 12
007 #31 enter 31
008 →DATE create last day of previous year in current date mode.
009 X<>Y
010 ΔDAYS days from 1st of year
011 STO 05
012 5 Offest from UTC (-5 represents EST)
013 +/- Offest from UTC (-5 represents EST)
014 STO 03 Local time offset from UTC
015 9
016 0
017 .
018 5
019 ->HR 90.83333333333333 entered for degrees from zenith
020 STO 06 degrees from zenith for Sunrise. May be changed if
021 3 Latitude
022 5 Latitude
023 . Latitude
024 1 Latitude
025 2 Latitude
026 3 Latitude
027 4 Latitude
028 5 Latitude
029 STO 01 35.12345 for example (decimal)
030 9 Longitude
031 0 Longitude
032 . Longitude
033 5 Longitude
034 4 Longitude
035 3 Longitude
036 2 Longitude
037 1 Longitude
038 +/- Longitude
039 STO 02 -90.54321 for example (decimal)
040 #015 15 Degrees per hour
041 STO 19 Store for later use
042 /
043 STO 07 Longitude hour value (lngHour)
044 #018
045 XEQ 05 Calculate approximate time for sunset
046 XEQ 06
047 STO 15 Done calculating sunset. Store the result
048 6 Calculate sunrise
049 XEQ 05
050 RCL 17 Recall 360
051 RCL- Y
052 XEQ 06
053 RCL 15 Recall sunset. Push sunrise to Y.
054 CL alpha clear alpha register for new text message
055 'Ris'
056 'e-S'
057 'et'
058 VIEWa Display text
059 PSE 25
060 CL alpha clear alpha register for new text message
061 alphaRC# Y copy Y register value to alpha register
062 VWalpha+ X view alpha (sunrise) in dot-matrix, sunset time in X register.
063 STOP
064 CPX STO Z store sunrise and sunset times in Z and T
065 ->HR convert sunrise time to decimal hours
066 x<>y swap x and y
067 ->HR convert sunset time to decimal hours
068 - subtract for decimal hour day length
069 ->H.MS convert day length to HMS
070 CL alpha
071 'Day'
072 ' Le'
073 'ngt'
074 'h'
075 VWa+ X Display text and day length
076 RTN done
077 LBL 05 Subroutine for large common section
078 RCL- 07
079 #024 enter 24
080 /
081 RCL+ 05
082 STO 08 Approximate sunset time
083 .
084 9
085 8
086 5
087 6 enter 0.9856
088 x
089 3
090 .
091 2
092 8
093 9 enter 3.289
094 -
095 STO 09 Sun's mean anomaly
096 SIN Calculate sun's true longitude
097 1
098 .
099 9
100 1
101 6 enter 1.916
102 x
103 RCL+ 09
104 2
105 RCLx 09
106 SIN
107 .
108 0
109 2 enter 0.02
110 x
111 +
112 3
113 RCLx 09
114 SIN
115 3
116 SDR 004 enter 0.0003
117 x
118 +
119 2
120 8
121 2
122 .
123 6
124 3
125 4 enter 282.634
126 +
127 3
128 6
129 0 enter 360
130 STO 17
131 MOD
132 STO 10 Sun's true longitude
133 TAN Calculate sun's Right Ascension
134 .
135 9
136 1
137 7
138 6
139 4 enter 0.91764
140 x
141 ATAN
142 RCL 17 enter 360
143 MOD
144 STO 11 Sun's Right Ascension
145 RCL 10
146 #090 enter 90
147 STO 18 Store for later use
148 /
149 FLOOR
150 RCLx 18 Recall 90 and multiply
151 +
152 RCL 11
153 RCL/ 18 Recall 90 and divide
154 FLOOR
155 RCLx 18 Recall 90 and multiply
156 -
157 RCL/ 19 Recall 15 and divide
158 STO 11 Sun's Right Ascension converted into hours
159 RCL 10
160 SIN
161 .
162 3
163 9
164 7
165 8
166 2 enter 0.39782
167 x
168 STO 12 sinDec for sunset
169 ASIN
170 COS
171 STO 13 cosDec for sunset
172 RCL 06
173 COS
174 RCL 01
175 SIN
176 RCLx 12
177 -
178 RCL 01
179 COS
180 RCLx 13
181 / Sun's local Hour Angle (cosH)
182 ACOS
183 RTN
184 LBL 06 Subroutine for another common section
185 RCL/ 19 Recall 19 and divide
186 RCL+ 11
187 .
188 0
189 6
190 5
191 7
192 1 enter 0.06571
193 RCLx 08
194 -
195 6
196 .
197 6
198 2
199 2 enter 6.622
200 -
201 #024 enter 24
202 MOD
203 RCL- 07
204 RCL+ 03
205 ->H.MS
206 END
