08-12-2015, 03:05 AM
I am taking an online class in R Programming language (http://www.edx.org), having a great time. The program BOOLLIST is based on the ability in R to pick out elements using logical elements (TRUE, FALSE).
Example (in R):
vector <- [2, 3, 4, 5]
vector[ c(TRUE, TRUE, FALSE, TRUE) ] returns [2, 3, 5]
The logical vector doesn’t have to be same length as the source vector. If the logical vector has elements than the source vector.
vector <- [1, 2, 3, 4, 5, 6]
vector[ c(TRUE, FALSE, TRUE, FALSE, TRUE, FALSE) ] returns [1, 3, 5]
vector[ c(TRUE, FALSE) ] returns [1, 3, 5] (TRUE, FALSE pattern recycles)
Program BOOLLIST:
Input: BOOLLIST(source list, logical list)
Notes: Use list brackets { }. For the logical list, use 1 for TRUE and 0 for FALSE.
Examples:
In addition to the examples above that can be tried with BOOLLIST:
BOOLLIST( {4,2,3,6}, {1,0,0,1} ) returns {4, 6}
BOOLLIST( {3,9,6,-1,6}, {1,0} ) returns {3, 6, 6}
http://edspi31415.blogspot.com/2015/08/h...using.html
Example (in R):
Program BOOLLIST:
EXPORT BOOLLIST(LA, LB)
LOCAL LC, n, s, k, j;
// Initialization
LC≔{ };
j≔1;
s≔SIZE(LA);
b≔SIZE(LB);
// Process
FOR k FROM 1 TO s DO
IF LB(j)==1 THEN
LC≔CONCAT(LC,LA(k));
j≔j+1;
IF j>n THEN
j≔1;
RETURN LC;
Examples:
