07-09-2015, 07:35 AM
Quote:Please welcome our newest member, 1332881954
1332881954 has 2 representations as a sum of 2 squares:
\(1332881954 = 6277^2+35965^2 = 23927^2+27575^2\)
Welcome to this forum
(07-11-2015 05:30 PM)Gerson W. Barbosa Wrote: [ -> ]\[\frac{3}{2}\cdot \pi ^{18}+\frac{6!-5!+\frac{\pi ^{-\pi }}{9}}{7}\cdot \pi ^{4}\]
(07-12-2015 11:08 AM)Thomas Klemm Wrote: [ -> ](07-11-2015 05:30 PM)Gerson W. Barbosa Wrote: [ -> ]\[\frac{3}{2}\cdot \pi ^{18}+\frac{6!-5!+\frac{\pi ^{-\pi }}{9}}{7}\cdot \pi ^{4}\]
I'm always amazed by your pandigital expressions. Do you use a program to find them?
(07-12-2015 03:22 PM)rprosperi Wrote: [ -> ]Does 'pandigital' imply each digit is used only once?
Quote:From Ancient Greek πᾶν (pân), neuter form of πᾶς (pâs, “all, every”)pan
Quote:From Latin digitālis, from digitus (“finger, toe”) + -alis (“-al”).digital
Quote:You guys amaze me...
(07-12-2015 01:47 PM)Gerson W. Barbosa Wrote: [ -> ]No program, only a WP 34S set to double precision and about one hour's time.
(07-11-2015 10:11 PM)PANAMATIK Wrote: [ -> ]Now, after this is done, I probably don't know what to do with the coming sunday
(07-12-2015 04:26 PM)Gerson W. Barbosa Wrote: [ -> ]\[e \sqrt[12]{e^{-3\times 4}+5.67890}\]
(07-12-2015 05:04 PM)Thomas Klemm Wrote: [ -> ](07-12-2015 04:26 PM)Gerson W. Barbosa Wrote: [ -> ]\[e \sqrt[12]{e^{-3\times 4}+5.67890}\]
Genius! 3.141592654571540303409367866518360732739326280463671619184479...
(07-12-2015 04:26 PM)Gerson W. Barbosa Wrote: [ -> ](07-12-2015 03:22 PM)rprosperi Wrote: [ -> ]Does 'pandigital' imply each digit is used only once?
As Thomas has explained above, this hybrid compound noun means "all digits". Therefore, pandigital doesn't necessary imply only one instance of each digit, but it's better in this kind of play. Even better when the digits are in order :-)
But this was a very lucky one, I wonder if I will ever come up with something like that again! Also, this one works nicely on the Voyagers, even on the HP-12C, which lacks π.
Gerson.
(07-12-2015 05:59 PM)Gerson W. Barbosa Wrote: [ -> ]Thanks, but I think you'll change your mind when you know about my higher mathematical methodology
(07-12-2015 06:24 PM)rprosperi Wrote: [ -> ]This goes into my collection of amazing equations that are cool just to look at.
(07-12-2015 06:20 PM)rprosperi Wrote: [ -> ]How long did this one take?
(07-12-2015 07:14 PM)Gerson W. Barbosa Wrote: [ -> ]Beauty-wise, nothing surpasses the following real identity, by a real genius:
\[e^{i\pi }+1=0\]
(07-12-2015 08:36 PM)rprosperi Wrote: [ -> ]While just about any post from XKCD is worth a look, this one is new to me.
