from the 8151 firmware update to the partfunc function does not return the correct results.
How I can fix this?
How I can downgrade my calculator?
![[Image: l2YJXw3.png]](http://i.imgur.com/l2YJXw3.png)
I never run partfrac with approx input, it explains that I did not track the unsimplified terms. Please run it in exact mode until I can fix it.
A workaround for the moment is to put your original input inside an exact( ) call. An easy way to do this is pressing the a b/c key inside the CAS screen. It will convert your numbers into exact fractional representations.
Thank you for the report.
![[Image: wvecuq.jpg]](http://i57.tinypic.com/wvecuq.jpg)
this is a good solution but it is not the best, I hope you can solve. thanks
