Here is my attempt to truncate a long real imitating the real function TRNC.
For long real input
%% 5.12345678901
%% 5
the programme returns
%% 5.12345
& for input
%% 5.12345678901
%% -5
returns
%% 5.1234.
I find it hard to believe this is the most economical way to do it.
Can you suggest a less long-winded programme?
CK2&Dispatch
# 3F3F
DUP%%0=_
casedrop
DUP
DUP%%0=_
?SEMI
DUP
%%ABS
SWAP
%%ABS
%%INT
DUP
%%ABS
%%.5
%%INT
SWAP
DUP%%0=_
?SEMI
DUP
%%ABS
DUP
%%0>
DUP
4PICK
DUP
%%INT
%%0=
AND
case2DROP
?SKIP
%%1+_
%%ABS
SWAPDUP
%%ABS
%%LN
%%10
%%LN
%%INT
SWAP
%%ABS
%%10
OVER
%%ABS
%%LN
%%10
%%LN
%%INT
%%10
4ROLL
%%INT
%%ABS
%%10
OVER
%%ABS
%%LN
%%10
%%LN
%%INT
%%10
ROT
Hi Gerald,
you may use strings for truncating a long real, e.g:
5.12345678901
ENTER
->STR
this converts your real into the string "5.12345678901"
now enter:
1
ENTER
5
ENTER
SUB
ENTER
this truncates your string after the 5th charachter: "5.123"
The last step is to convert the string back to a real:
STR->
ENTER
This leaves 5.123 on Level 1 of the stack.
The only problem is that you need to know the number of charachters to the left of the decimal point because the SUB command strictly counts from left to right.
Hope this helps
Best regards
Karl
Thank you, Karl-Ludwig, for your suggestion.
However, for input
%% 7.12345678901234
%% 13
your method fails.
Hi Gerald,
I just tried the example you mentioned. 13 decimal places from 7.12345678901234 should leave 7.1234567890123 but because the ->STR routine converts only 11 decimal places to string, the maximum is 11 decimal places. If you can avoid the ->STR routine by inputing the number as string, this limitation of the ->STR routine would not occur.
Best regards
Karl
I'm not sure you know what a long real is.
Try this:
Place
1.234
on the stack & apply the command ->S2 (that's right arrow S 2), you should see
"% 1.234
This is how a real number decompiles.
Now apply the command ASM to the last result & you have 1.234 again.
If you change
"% 1.234
to
"%% 1.23456789012345
& apply ASM you will now see a long real on the stack, having 15 rather than 12 digits.
(07-06-2015 07:49 PM)Gerald H Wrote: [ -> ]Here is my attempt to truncate a long real imitating the real function TRNC.
How about using →H and H→ to convert to string?
→H on 1.23456789012345 will give you:
5592000000
5432109876543210"
The first 5 digits are the prolog, the next 5 are the exponent (0 in this case), and then you have your 15 digits, and the sign digit at the end.
Truncating to a certain number of significant digits is easy, all you have to do is to replace the appropriate digits with zero and run H→.
Truncating to a number of decimals after the dot can be tricky, you need to "read" the exponent to know where the dot would be, then replace the proper digits with zeros.
Interesting approach, Claudio.
How would you deal with
%% 5.678E1234
to 3 decimal places? The mantissa & exponent are nicely separated in this representation, after ->H you have to work them out yourself.
& remember the 3 could be negative, just as in the TRNC function for normal reals.
Your suggestion may be a good approach....until you work out the details I think it will probably end up longer than my effort.
I will be very happy to be proven wrong.
(07-07-2015 01:54 PM)Gerald H Wrote: [ -> ]Interesting approach, Claudio.
%% 5.678E1234
OK, challenge accepted. Here it is (in UserRPL). Looks a lot longer because of the comments:
SWAP ->H 0.
-> N S TPOS <<
@@ N=NUMBER OF DIGITS, S=STRING REPRESENTATION
@@ TPOS = POSITION OF TRUNCATION
IF N 0 < THEN
@@ WHEN N<0, TOTAL SIGNIFICANT FIGURES IS THE EASY CASE
15. N + 'TPOS' STO
ELSE
@@ N>=0, N IS SIGNIFICANT FIGURES AFTER THE DECIMAL DOT
@ WE NEED THE EXPONENT
S 6. 10. SUB
"339204000000000" SWAP + "0" + H->
@ HERE WE HAVE THE EXPONENT IN TEN'S COMPLEMENT AS A REAL
@ CONVERT IT TO A NEGATIVE NUMBER
DUP IF 50000. > THEN 100000. - END
@ NOW LET'S COMPUTE THE POSITION OF THE LAST DIGIT WE WANT
14. SWAP - N -
'TPOS' STO
END
@@ NOW WE KNOW THE POSITION OF TRUNCATION, JUST DO THE MAGIC
@ IF MORE THAN 15, THE NUMBER WOULD BE ALL ZEROS, KEEP AT 15
TPOS IF 15. > THEN 15. 'TPOS' STO END
IF TPOS 0. > THEN
@ SEPARATE PROLOG AND EXPONENT
S 1. 10. SUB
@ PAD WITH ZEROES AS NEEDED
"000000000000000" 1. TPOS SUB
@ NOW ADD THE DIGITS WE WANT TO KEEP
S 11. TPOS + 26. SUB
@ AND PUT IT ALL BACK TOGETHER
ELSE
@ NOTHING TO DO, RESTORE THE ORIGINAL NUMBER
S
END
H->
Bravo, Claudio!
Your programme works!
I include a code box for your programme to display it more clearly.
I haven't fully tested the programme yet, however for input
1.41421356237309E-12345
5.
it returns
0E-12345
Correct, but I prefer
0E0
Your programme is 435.5 Bytes while my latest version is 110 Bytes.
« SWAP ->H 0. -> N S TPOS
IF N 0 <
THEN 15. N + 'TPOS' STO
ELSE S 6. 10. SUB "339204000000000" SWAP + "0" + H-> DUP
IF 50000. >
THEN 100000. -
END 14. SWAP - N - 'TPOS' STO
END TPOS
IF 15. >
THEN 15. 'TPOS' STO
END
IF TPOS 0. >
THEN S 1. 10. SUB "000000000000000" 1. TPOS SUB S 11. TPOS + 26. SUB + +
ELSE S
END H->
(07-07-2015 04:48 PM)Gerald H Wrote: [ -> ]Bravo, Claudio!
5.
it returns
0E-12345
0E0
Yes, one consequence of direct manipulation of digits is that zero becomes denormalized. It shouldn't cause any problems when operating on it, and can easily be solved by adding %% 0. to the final result (but you can't do that in userRPL, you'd have to port the code to sysRPL).
It should be easy to port to sysRPL to save a few more bytes (or at least eliminate the local variables), but where the idea will shine is in Saturn ASM, as the manipulation of digits can be done directly in a register instead of a string, which would make it extremely small and fast. also reading the exponent is trivial in ASM, but requires quite some work in userRPL.
Here my improved version of the truncation programme for long reals, replicating the built in TRNC function for reals.
So the winner of the challenge is me, unless someone publishes a better programme, an extremely unlikely eventuality.
CK2&Dispatch
# 3F3F
%0
RNDXY
DUP
%%0<
IT
%%ABS
OVER
DUP%%0=_
?SEMI
%%ABS
%%LN
%%10
%%LN
%%INT
%%1+_
%%10
SWAP
DUPUNROT
DUP
DUP%%0=_
?SEMI
DUP
%%ABS
SWAP
%%ABS
%%INT
SWAP%%/
