How can I create a user defined function to map two variables into a vector on the prime?
i.e. something along the lines of:
defvect(angle, magnitude):=[magnitude*cos(angle), magnitude*sin(angle)]
but that works.
OK so I solved my task by making it a program
EXPORT DEFVECT(mag,ang)
RETURN([mag*COS(ang),mag*SIN(ang)]);
But that really feels like tapping an exposed nail head with a sledge hammer. Is there no way to return a vector or matrix from the 'Define' window?
Here is a way to return a vector from a User Defined function (a bit cumbersome but it seems to work…):
attachment=2273]
But in your case it's much more simpler to use the existing rectangular_coordinates() function:
attachment=2274]
By using a list first, try this function, which will create the variables M0, mag, and ang. (Uncheck the [M0]):
[Shift] [Define]
Function: M0:=list2mat({mag*COS(ang), mag*SIN(ang)})
M0:[ ] mag:[ ✔] ang:[ ✔]
oops, I see Didier beat me to it!
Thanks to both of you for the solution and pointing out the built in function.
