06-28-2015, 12:27 PM
For input
Programme taking one argument from & returning one argument to the stack
Lower bound of integration
Upper bound of integration
the programme GK returns a numerical integral accurate to screen display setting.
eg For STD display
<< LN INV >>
2
98765432167
the programme returns
4069312104.01
in 33.12 sec
& for 4 FIX
406959338.70
in 5.74 sec.
For sub-programmes see below GK.
eg For STD display
<< LN INV >>
2
98765432167
4069312104.01
in 33.12 sec
& for 4 FIX
406959338.70
in 5.74 sec.
GK
CK3&Dispatch
# 811
ID x0AE
4UNROLL
CK3
3DROP
x0AE
2DUP
2DUPSWAP
2DUP
%2
3UNROLL
%2
4PICK
8PICK
EVAL
DUPTYPEREAL?
NcaseTYPEERR
4PICK
9PICK_
EVAL
%0
DUPDUP
NULLLAM
BINT9
NDUPN
DOBIND
% .942882415695
% .816496580928
% .641853342346
% .4472135955
% .236383199662
%0
BINT6
ONE_DO
INDEX@
#2*
PICK
%CHS
LOOP
BINT11
ZERO_DO
6GETLAM
7GETLAM
BINT14
PICK
EVAL
BINT11
UNROLL
LOOP
8PICK
5PICK
%5
5GETLAM
4GETLAM
DUP
7PUTLAM
6GETLAM
%6
3PUTLAM
10PICK_
3PICK
% 432.
9PICK_
6PICK
% 625.
7PICK
% 672.
7GETLAM
% 77.
6GETLAM
% 1470.
2PUTLAM
BINT11
ROLL
% 9.42738402189E-2
SWAP
BINT10
ROLL
% .155071987337
%+SWAP
8ROLL
% .18882157396
%+SWAP
6ROLL
% .199773405227
SWAP4ROLL
% .224926465333
%+SWAP
% .242611071901
7GETLAM
% 1.58271919735E-2
6GETLAM
DUP1PUTLAM_
2GETLAM
%ABS
3GETLAM
1GETLAM
%ABS
DUP%0=
ITE
2DROP
%1
ID x0B1
% .00000000001
%MAX
SWAPDUP
%0>
OVER
%1
ANDITE
DROP
9GETLAM
8GETLAM
5GETLAM
4GETLAM
1GETLAM
DUP%0=
IT
DROP
8GETLAM
9GETLAM
%ABS
ABND
9PICK_
7ROLL
TRUE
LAM 3
LAM 2
LAM 1
BIND
ID x0AF
1GETABND
?SEMI
ID x0B0
5UNROLL
x0B1
%.1
BINT0
BINT4
ZERO_DO
#2*
BINT48
INDEX@#-
TestSysFlag
IT
#1+
LOOP
DUP#0=csedrp
BINT12
FPTR2 ^RP#
x0AF
4PICK
6PICK
2DUP
%2
3UNROLL
%2
2DUP
2DUP
% .816496580928
2DUP
5UNROLL
3UNROLL
% .4472135955
2DUP
4UNROLL
4PICK
4PICK
8PICK
5PICK
5PICK
BINT5
ZERO_DO
LAM 3
EVAL
5UNROLL
LOOP
NULLLAM
BINT16
NDUPN
DOBIND
14GETLAM
13GETLAM
4GETLAM
1GETLAM
2DUP
%5
10GETLAM
%6
SWAP
% 625.
ROT
% 77.
5GETLAM
2GETLAM
% 432.
3GETLAM
% 672.
10GETLAM
% 1470.
DUPROT
%ABS
12GETLAM
LAM 2
9GETLAM
16GETLAM
OR
15GETLAM
7GETLAM
DUPUNROT
ORcase
ABND
LAM 1
AND
NOT?SEMI
ID x0B0
DISPROW5
FALSE'
LAM 1
STO
2DROP
16GETLAM
9GETLAM
14GETLAM
5GETLAM
9GETLAM
8GETLAM
5GETLAM
4GETLAM
8GETLAM
11GETLAM
4GETLAM
3GETLAM
11GETLAM
6GETLAM
3GETLAM
1GETLAM
6GETLAM
7GETLAM
1GETLAM
2GETLAM
7GETLAM
15GETLAM
2GETLAM
13GETLAM
%0
BINT6
ZERO_DO
5UNROLL
12GETLAM
ID x0AF
LOOP
ABND
x0B0
"Out of Tolerance"
