A
video to start with.
A
wikipedia page for the algorithm.
And some code for the 50g
%%HP: T(3)A(R)F(,);
\<< 0 1 1 0 1 \-> N A B C D nb
\<< N 'D' STO A B /
WHILE C N <
REPEAT 'nb' INCR DROP N B + D / IP R\->I DUP C * A - SWAP D * B - C 'A' STO D 'B' STO 'D' STO 'C' STO A B /
END nb \->LIST
Usage: enter order N and call the function; returns list of items for the Farey sequence order N.
(06-15-2015 08:53 PM)Thomas Klemm Wrote: [ -> ]More fun …
Nice!
Note: Had no idea one could sum List with objects to push back that object in the list. The 48 code is very slim.
Thanks for the links. Great video !
I've adapted the Python program for the Prime:
#pragma mode( separator(.,;) integer(h32) )
EXPORT farey(n)
LOCAL a:=0,b:=1,c:=1,d:=n,k,l;
l:={ a/b };
WHILE c < n DO
k:=IP((n+b)/d);
c:=−a+k*(a:=c); d:=-b+k*(b:=d);
l:=CONCAT(l,a/b);
exact(l);
The result is a list of reals, you need to press the "a b/c" key to display it as fractions. I don't know how to do it programmatically.
EDIT: edited to add exact() to the result as suggested by Joe below.
(06-16-2015 07:09 PM)Didier Lachieze Wrote: [ -> ]The result is a list of reals, you need to press the "a b/c" key to display it as fractions. I don't know how to do it programmatically.
The "exact" function will serve your purposes.
exact({1.2, 3.4}) returns {6/5, 17/5}, even in a Home program. Doesn't work on arrays in Home, just lists. Works on arrays and lists in CAS programs, though.
(06-15-2015 10:34 PM)Tugdual Wrote: [ -> ]The 48 code is very slim.
yes and you can have the UserRPL program returning the same result as the SysRPL version (a list of algebraic fractions) by replacing:
a b →V2 + by:
a b / →Q +
(06-23-2015 09:54 AM)Gerald H Wrote: [ -> ]
5UNROLL ( … a b c d )
4ROLL ( … b c d a )
4ROLL ( … c d a b )
2GETLAM ( … c d a b n )
OVER#+ ( … c d a b n+b )
4PICK ( … c d a b n+b d )
#/ ( … c d a b k )
SWAPDROP ( … c d a k )
Couldn't that be replaced by:
4ROLL ( … b c d a )
4ROLL ( … c d a b )
#+ ( … c d a n+b )
3PICK ( … c d a n+b d )
#/ ( … c d a k )
Unfortunately I'm not familiar with the HP-49/50. In addition to that I wasn't able to compile your program successfully with Debug4x. It appears to be a problem with flash-pointers:
Entry FPTR2 does not exist.
Therefore I can't run the program and must admit that I don't fully understand what's going on in this section:
OVER
FPTR2 ^#>Z
OVER
FPTR2 ^#>Z
FPTR2 ^NDXFext
Would you mind explaining it? Maybe even provide stack diagrams as comment?
Without these I would have had a hard time to understand how the HP-48 is
calculating complex arccos and arcsin functions.
Kind regards
Dear Thomas,
The code replacement you suggest is not good.
#/ is bint division, stack diagram
bint a bint remainder(a/b)
bint b -> bint quotient(a/b)
FPTR2 ^NDXFext does exist, stack diagram
zint a
zint b -> 'zint a/zint b'
You may have a problem with Z0_ which is shorthand for ZINT 0
The section you don't fully understand does this
bint a
bint a bint b
bint b -> 'zint a/zint b'
I suggest you change Z0_ to ZINT 0 & try to compile again.
Thanks for your interest.
(06-25-2015 05:46 AM)Gerald H Wrote: [ -> ]#/ is bint division, stack diagram
From "Programming in System RPL" by Eduardo M Kalinowski and Carsten Dominik:
Addr. Name Description
303E9 %/ ( % %' → %/%' )
303D3 %%/ ( %% %%' → %%/%%' )
03EF7 #/ ( # #' → #r #q )
Thus
#/ is what is called
/MOD in Forth:
/MOD ( n1 n2 -- rem quot ) Divides. Returns the remainder and quotient.
Who would think that this was a good idea to use
#/ instead?
Thanks for the explanation of
^NDXFex. I assumed something like this but didn't know where to look it up.
Quote:Thanks for your interest.
I try my best to keep up with your production of programs. But I must admit that I'm not fluent in
System RPL. Thus I'm a slow reader.
