06-15-2015, 03:25 PM
I could swear I had a direct formula for this at one point, but I'm totally drawing a blank.
Suppose I've got n standard 6-sided dice, numbered 1 through 6. Is there a formula for calculating the frequency (i.e. number of different permutations) of rolling a given total? For example, what are the odds of rolling a total of 22 on 9 dice? (It's about 1.45% in this case.)
The brute-force approach is really simple on SQL Server (code below), and runs all ~10 million permutations in about 1-2 seconds on the server I've got access to, but my HP 48 probably won't be so quick.
And for extra fun, I'm also wondering if such a formula could be extended to rolling a pool of non-standard, mixed dice, e.g. maybe three of them numbered 0, 0, 0, 1, 2, 3, two numbered 0, 0, 1, 2, 2, 3, and one with 0, 0, 1, 2, 3, 4. The brute-force approach can be adapted for this trivially.
The motivation behind this would be in case I'm playing a board game and want to quickly math out my odds of success before diving into a potentially pivotal move.
WITH die AS (
SELECT v FROM (VALUES (1), (2), (3), (4), (5), (6)) v(v)
freq AS (
SELECT
d1.v + d2.v + d3.v + d4.v + d5.v + d6.v + d7.v + d8.v + d9.v AS total,
COUNT(*) AS freq
FROM die d1
CROSS JOIN die d2
CROSS JOIN die d3
CROSS JOIN die d4
CROSS JOIN die d5
CROSS JOIN die d6
CROSS JOIN die d7
CROSS JOIN die d8
CROSS JOIN die d9
GROUP BY d1.v + d2.v + d3.v + d4.v + d5.v + d6.v + d7.v + d8.v + d9.v
SELECT
total,
freq,
CAST(freq AS float) / CAST(SUM(freq) OVER (PARTITION BY NULL) AS float) AS pct,
SUM(freq) OVER (PARTITION BY NULL) AS perms
FROM freq
ORDER BY total
