I need to whip up a quick moving-average program. This doesn't work:
AVG:
\<< DUP \GSLIST SWAP SIZE / \>>
MAVG:
\<< \-> L N
\<< L N \<< N \->LIST AVG \>> DOSUBS \>>
And it's fairly obvious why: DOSUBS doesn't like the local name 'N' being present in the program it's being passed.
What's the trick to modifying a program on the stack? I figure I should be able to recall the value of N, prepend it to \<< ->LIST AVG \>>, and have a program that DOSUBS will take. You can't simply concatenate programs with +, and while it works with lists, DOSUBS won't accept the function stored as a list.
? But it does work, and DOSUBS has no issues with local variables being in the executable object..
{ 1 2 3 } 2 MAVG returns { 1.5 2.5 } as it should
BTW you don't need to include L in your local environment
MAVG:
\<< \-> N
\<< N \<< N \->LIST AVG \>> DOSUBS \>>
Cheers, Werner
(06-12-2015 02:55 PM)Werner Wrote: [ -> ]? But it does work, and DOSUBS has no issues with local variables being in the executable object..
MAVG:
\<< \-> N
Cheers, Werner
Alright, that's weird... At first, I was getting "DOSUBS Error: Invalid User Function". Not sure what bizarre typo was leading to that.
Anyway, if anybody knows how to modify programs and convert them to/from lists, I'd still find that useful.
(06-12-2015 03:03 PM)Dave Britten Wrote: [ -> ]Anyway, if anybody knows how to modify programs and convert them to/from lists, I'd still find that useful.
Convert the program to a string with →STR, modify to your heart's content, and then convert back to a program with OBJ→. This has the advantage that it forces a recompile of the program so that your changes are guaranteed to take effect.
Edit: I think I'm mis-remembering the compiling thing, which only applies to algebraics.
- John
(06-12-2015 03:26 PM)John R. Graham Wrote: [ -> ] (06-12-2015 03:03 PM)Dave Britten Wrote: [ -> ]Anyway, if anybody knows how to modify programs and convert them to/from lists, I'd still find that useful.
- John
That should work in most cases, including this one, but if the program has any non-UserRPL stuff in it, e.g. takeovers, externals, etc., then recompiling it from the string representation will probably either fail with an error, or store a broken program.
I could swear I saw some method to build/modify a program on the fly without doing any string conversions. Can't remember where I saw it, though. It may have been an algebraic-to-RPN converter, unless I'm imagining the existence of that too.
Interesting. If you (re-)locate such a feature, I'd love to hear about it.
- John
By converting programs to lists and back again, are you referring to the →LST and →PRG command in library 256? If you execute 256.02 MENU, you'll see →LST on the F5 key. Pressing it with a program on the stack will turn it into a list, which can easily be exploded to the stack via OBJ→, or manipulated like any other list. Then press NXT to see →PRG on the F1 key. It takes any list and turns it into a program.
If that's not what you were looking for, ignore this posting.
Wow. Those descriptions are so terse in the AUR that I hadn't realized what they did. Thank you.
- John
(06-12-2015 05:50 PM)Joe Horn Wrote: [ -> ]By converting programs to lists and back again, are you referring to the →LST and →PRG command in library 256? If you execute 256.02 MENU, you'll see →LST on the F5 key. Pressing it with a program on the stack will turn it into a list, which can easily be exploded to the stack via OBJ→, or manipulated like any other list. Then press NXT to see →PRG on the F1 key. It takes any list and turns it into a program.
That sounds like what I was thinking of.
Now, how do I do that on a 48, which doesn't have menu 256?
(06-12-2015 06:23 PM)Dave Britten Wrote: [ -> ]That sounds like what I was thinking of. Now, how do I do that on a 48, which doesn't have menu 256?
Gotta use System RPL, but that can be faked with SYSEVAL in a User RPL program. Delightfully, the SRPL command CHANGETYPE has remained stable at ROM address #05AB3h in every RPL model, from 48SX version A, through the 48GX version R, through the 50g version 2.15. So the following little routine will convert any program into a list or vice versa, and leave any other input unchanged. It's non-optimized for ease of human reading... if such a thing is possible in RPL. Be sure to get the hex numbers exactly right, or it'll do Bad Things.
'P~L' (Program/List Toggler) for HP 48/49/50, all versions
<< CASE
DUP TYPE 8 ==
THEN #2A74h #5A03h SYSEVAL #5AB3h SYSEVAL END
DUP TYPE 5 ==
THEN #2D9Dh #5A03h SYSEVAL #5AB3h SYSEVAL END
END >>
(06-12-2015 09:56 PM)Joe Horn Wrote: [ -> ] (06-12-2015 06:23 PM)Dave Britten Wrote: [ -> ]That sounds like what I was thinking of. Now, how do I do that on a 48, which doesn't have menu 256?
<< CASE
DUP TYPE 8 ==
DUP TYPE 5 ==
END >>
Sweet, thanks. I figured there might be a couple of SYSEVALs that would do that.
