The following code was inspired by Dave Britten:
\<< SWAP 4 ROLL - SWAP
ROT - R\->C DUP ARG DUP
0 <
\<< 360 +
\>> IFT SWAP ABS
Input:
4:N1
3:E1
2:N2
1:E2
Output:
2:Azimuth
1:Distance
Mark
(06-07-2015 10:51 PM)MNH Wrote: [ -> ]Hello,
0 <
\<< 360 +
\>> IFT SWAP ABS
Input:
4:N1
3:E1
2:N2
1:E2
Output:
2:Azimuth
1:Distance
Mark
So you assume the calculator is set to DEGREES
Another way of doing it can be:
\<< RECT \->V2 UNROT \->V2 - CYLIN V\-> 360 MOD SWAP \>>
Cheers,
Thanks for replying! My calculator is in DEG mode. Your code didn't work with my input.
Input:
4:5,000.0000
3:5,000.0000
2:5,300.0000
1:5,400.0000
Output:
3:[7,566.3730 <45.5355]
2:45.0000
1:7,071.0678
Will have to investigate! How do you make the measured angle symbol when posting in this forum?
(06-09-2015 07:22 PM)Thomas Klemm Wrote: [ -> ] (06-09-2015 01:48 PM)MNH Wrote: [ -> ]How do you make the measured angle symbol when posting in this forum?
Or then ∠ as suggested by: Mapping HP48 Text to Unicode
∡ looks more similar though.
(06-09-2015 07:26 PM)Massimo Gnerucci Wrote: [ -> ]∡ looks more similar though.
Quote:While ∡ 2221 is visually an even better match, this character often does not render properly on various computer platforms and software. In short, some users will just see empty boxes such as:
The article is from July 11, 2012. This character is rendered properly in my firefox browser.
(06-09-2015 08:59 PM)Thomas Klemm Wrote: [ -> ] (06-09-2015 07:26 PM)Massimo Gnerucci Wrote: [ -> ]∡ looks more similar though.
Ooops, didn't read down there! :)
However MNH asked for "the measured angle symbol"
∠U+2220 ANGLE
∡U+2221 MEASURED ANGLE
Another way is using LaTex: \(\measuredangle\) (\measuredangle)
