Hi
I have a problem with a simple program when it is launched from the PROGRAM window in RPN mode. Here is the program :
EXPORT TEST(N)
PRINT(N);
When I press the exec button in the PROGRAM menu, I have a from asking for N. I type 5214 for example and when i press OK to valid the form, the calculator reboots
If I disable RPN mode, everything is fine, but I do prefer RPN mode !
I couldn't reproduce the bug. Maybe you should reset it and try again?
It's hard to imagine a shorter program to crash the equipment, but apparently any number greater than 999 for N, (in your program), crashes mine. When the device reboots, we're reset back in textbook entry mode, too! (The other settings remained the same).
(06-07-2015 05:27 PM)DrD Wrote: [ -> ]It's hard to imagine a shorter program to crash the equipment, but apparently any number greater than 999 for N, (in your program), crashes mine. When the device reboots, we're reset back in textbook entry mode, too! (The other settings remained the same).
Same here.
D**n.
EDIT: Lucky for HP that most students don't use or like RPN.
(How funny is that?)
As I continue to see how many HP Prime bugs are being identified by the members in this forum, I have to ask if those at HP might consider including a number of these members in the beta test group for new releases... Tim?
This one is shorter:
EXPORT FOO(N) BEGIN END;
It is the parameter parsing that crashes the calc, not the print
