Full Version: Bug in (7820) - REDIM
REDIM does not work in Home, but works in CAS. In the program can be used CAS.REDIM but it's slower than it should.
(06-04-2015 04:51 PM)slawek39 Wrote: [ -> ]REDIM does not work in Home
Works fine here... REDIM(M1,{2,3}), REDIM(u1,5) etc
(06-04-2015 04:57 PM)Tim Wessman Wrote: [ -> ]
It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
The matrix is unchanged
(06-04-2015 05:04 PM)slawek39 Wrote: [ -> ]
(06-04-2015 04:57 PM)Tim Wessman Wrote: [ -> ]Works fine here... REDIM(M1,{2,3}), REDIM(u1,5) etc
It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
Same here. Matrix unchanged.
To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode.
(06-04-2015 06:37 PM)John Colvin Wrote: [ -> ]To clarify, REDIM doesn't work in HOME in RPN mode. Works ok in Textbook mode.
Correction: REDIM does work in RPN mode, but you gotta use it with RPN syntax (because you're in RPN mode!). Example: 'M1' [Enter] {3,4} [Enter] REDIM [Enter]
(06-04-2015 05:28 PM)Francois Lanciault Wrote: [ -> ]
(06-04-2015 05:04 PM)slawek39 Wrote: [ -> ]It does not work:
[[1,2],[3,4]]->M1
REDIM(M1,{2,4})
Same for me, whatever the mode (RPN, textbook or algebraic).
(06-06-2015 05:56 AM)Joe Horn Wrote: [ -> ]
I used the matrix template to create the matrix and then stored it in M1. Then I entered
'M1' and { 3, 4} and REDIM()--no change. Maybe something in the settings.
Anyway, does appear to be an issue here. Its on the list to resolve. Thanks.
