06-01-2015, 07:20 PM
userRPL historically had 4 different objects for vectors and matrices:
Vectors (1D)
Matrices (numeric only)
Symbolic Vectors (implemented as lists)
Symbolic Matrices (implemented as lists of lists)
Here we propose to simplify all this into a single object type: Matrix.
A matrix may contain real or complex numbers, or symbolic expressions mixed in. There is no difference between a symbolic matrix and a numeric one. Operations in newRPL follow generic overloadable operators, so addition and multiplication of individual elements can be done through the same generic operators and will automatically handle cross-type operations.
Vectors are not distinguishable from matrices in newRPL. They share the same object type and same properties and operations. When working with matrices, the following intuitive rules apply:
This proposal wouldn't break existing code, except that all conversions between matrix/vector and algebraic/numeric matrix become unnecessary.
In userRPL, multiplying a matrix by a vector works as described above, so it's nothing revolutionary but takes this concept a step further.
In newRPL a row vector (1xN) can be transposed to get a column vector (Nx1) (unlike userRPL, where it has to be converted to a matrix first, then transposed).
Multiplying two vectors of the same size becomes a dot product of vectors in newRPL (unless you specifically transpose one to make a (Nx1)x(1xN) multiplication, producing the expected (NxN) result).
The storage model for unified matrices is already implemented, but the matrix/vector fusion is not (yet), and I think a little feedback could help refine the idea.
Thoughts?
Vectors (1D)
- Operations on matrices follow the standard mathematical rules for addition/multiplication of matrices.
- All 1xN and Nx1 matrices are also considered one-dimensional vectors.
- One-dimensional vectors can be considered as row or column vectors (1xN and Nx1 matrices respectively) when operating with a matrix, whichever orientation makes the operation possible.
- Vector-vector additions are performed as matrix additions, but always producing a 1xN (row vector) when orientations don't match.
- Vector-vector multiplications are performed as matrix multiplications, and when orientations don't allow a valid operation, one vector is transposed to produce a (1xN)*(Nx1) = (1x1) multiplication.
Thoughts?
