05-30-2015, 06:03 PM
The Runge Kutta 4th Order is a method for solving differential equations involving the form: dy/dx = f(x,y), where:
x_n+1 = x_n + h
y_n+1 = y_n + (k1 + 2*k2 + 2*k3 + k4)/6
Where:
k1 = h * f(x_n, y_n)
k2 = h * f(x_n + h/2, y_n + k1/2)
k3 = h * f(x_n + h/2, y_n + k2/2)
k4 = h * f(x_n + h, y_n + k3)
Variables used:
A = x_n
B = y_n
C = x_n+1
D = y_n+1
H = step
K = k1
L = k2
M = k3
N = k4
Results are stored in lists L1 and L2. L1 represents the x coordinates, L2 represents the y coordinates.
Both DIFFTBL and RK4 return the same output. The difference is that DIFFTBL uses an Input box and no-pass through arguments and RK4 uses five pass-through arguments. This way, RK4 could be used as a subroutine.
Both return the results in a matrix, M1.
DIFFTBL:
RK4:
x_n+1 = x_n + h
Where:
Variables used:
A = x_n
B = y_n
C = x_n+1
D = y_n+1
H = step
K = k1
L = k2
M = k3
N = k4
DIFFTBL:
EXPORT DIFFTBL()
// EWS 2015-05-29
// Radian
HAngle:=0;
// Input
LOCAL f;
INPUT({{f,[8]},A,B,H,S},"Data Input",
{"dy/dx=","x0=","y0=","Step=",
"# Steps="});
L1:={A}; L2:={B};
// Main Loop
FOR I FROM 1 TO S DO
// k1
X:=A;
Y:=B;
K:=H*EVAL(f);
// k2
X:=A+H/2;
Y:=B+K/2;
L:=H*EVAL(f);
// k3
Y:=B+L/2;
M:=H*EVAL(f);
// k4
X:=A+H;
Y:=B+M;
N:=H*EVAL(f);
// point
A:=A+H;
B:=B+(K+2*L+2*M+N)/6;
L1:=CONCAT(L1,{A});
L2:=CONCAT(L2,{B});
M1:=list2mat(CONCAT(L1,L2),
SIZE(L1));
M1:=TRN(M1);
RETURN M1;
RK4:
EXPORT RK4(f,A,B,H,S)
// EWS 2015-05-29
// Radian
HAngle:=0;
// Input
L1:={A}; L2:={B};
// Main Loop
// k1
X:=A;
Y:=B;
K:=H*EVAL(f);
// k2
X:=A+H/2;
Y:=B+K/2;
L:=H*EVAL(f);
// k3
Y:=B+L/2;
M:=H*EVAL(f);
// k4
X:=A+H;
Y:=B+M;
N:=H*EVAL(f);
// point
A:=A+H;
L1:=CONCAT(L1,{A});
L2:=CONCAT(L2,{B});
SIZE(L1));
M1:=TRN(M1);
RETURN M1;
