Hello 50g freaks,
as I tried to program for example the integral from RPL to TeX I failed with my serial approach. Further analysis shows me that there a two kind of functions such like "+" with the operands surround and like int(...) with the arguments one after the other.
Similar to TeX. So I tried a second time the recursive approach (by the way, there is no need anymore for the little programs with the MATCH command, so it is really faster).
I made two programs \->HP2TEX and LOOKUP and a nested list TXPAT for the patterns.
\->HP2TEX is the main program
LOOKUP is the helper for searching in TXPAT.
\->HP2TEX has some restrictions:
a) No conversion from caps to small letters
b) If LOOKUP find no pattern in TXPAT it returns 0, this case will not be captured (means you get an error the program abort).
First the content of TXPAT every sublist has same structure:
Let us say you have RPL XROT (Read please the bigger italc comment further on!) command:
This function has two arguments -> sublist has four entries:
{ "XROT" "\\sqrt[" "]{" "}" } the double backslash is necessary otherwise you get no backslash. A function with four arguments has six entries and so on.
The advantage you can add simply rules as many you like. The counting is is fix if you needn't an element you can take "" (kind of nullstring) that doesn't change the output string, but the program works properly.
%%HP: T(3)A(R)F(,);
{ "*" "" "\\cdot " "" }
{ "/" "\\frac{" "}{" "}" }
{ "\->K" "\\left(" "\\right)" }
{ "\.S" "\\int_{" "}^{" "}" "d" "" }
{ "\v/" "\\sqrt{" "}" }
EDIT: XROOT decomposes in a inverse order like other function with two arguments: XROOT(A;B) OBJ\-> you get: B A 2, XROOT instead of
A B 2, XROOT so the translation rule fails.
My workaround is, if you have an algebraic expression with XROOT you use a little program with MATCH to convert 'XROOT(A;B)' into 'XROT(A;B)' (this function mustn't exist, but 'XROT(A;B)' decomposes into A B 2, XROT, so the translation rule works.
Now the code for LOOKUP:
%%HP: T(3)A(R)F(,);
\<< TXPAT SIZE 1, + \-> SGN NU
\<< 0,
DO
DROP 'NU' DECR @@Searching is from end
UNTIL @@to the beginning of the
IF 0, == @@list
THEN DROP 0, 1,
ELSE TXPAT NU GET
DUP HEAD SGN ==
END
END
And now the main program \->HP2TEX
%%HP: T(3)A(R)F(,);
\<< OBJ\-> @@Destruct object
IF OVER
THEN \-> N F @@Store fname
@@and number of arguments
\<< F N 1, + ROLLD @@store fname before arguments
@@on stack
1, N FOR J
IF DUP TYPE 9, == @@loop for analysing
@@every argument
THEN \->HP2TX @@if algebraic object
@@recursiv calling of
@@\->HP2TX
END
DUP @@argument or last
@@output of \->HP2TX
IF TYPE DUP @@local or global
@@name, if true
6, == SWAP
7, == OR
THEN \->STR DUP @@convert to a string
SIZE 1, - 2, @@and remove algebraic
SWAP SUB @@signs
ELSE \->STR @@numbers becomes
END @@a string
N ROLLD @@Roll down next
NEXT @@argument
N 1, + ROLL DUP @@self defined functions
IF TYPE DUP @@are from type
6, == SWAP @@local or global
7, == OR @@name
THEN \->STR DUP @@so they need
SIZE 1, - 2, @@same procedure
SWAP SUB @@like above
ELSE \->STR
END
LOOKUP \-> RULE @@at that position
@@stack line 1
@@is the fname as
@@a string
@@lookup is a program
@@which searches in
@@the global variable
@@texpat for a translation-
@@pattern from RPL to
@@TeX
@@the rule found is
@@stored in the local
@@RULE
\<< RULE TAIL @@the first entry of RULE
@@is the RPL fname, no need
@@any more
'RULE' STO
RULE HEAD @@next entry is the beginning
@@of the TeX command
1, N FOR J @@loop for alternating compo-
RULE TAIL @@sition of argument and
'RULE' STO @@syntax of TeX command
N J - 2, + ROLL
+ RULE HEAD +
NEXT
END
DUP 'OUT' STO @@display result as string and store
\>> @@and store it in global OUT
input: '\.S(1;2;\->K(A+B)^3;B)'
output:\[\int_{1}^{2}{\left(A+B\right)}^{3}dB\]
the function \->K produces only the parenthesis in TeX (in RPL there is no need for this ;-)) )
