(05-20-2015 09:25 PM)salvomic Wrote: [ -> ]I'm completing a program to calculate IRR, MIRR (modified IRR) and NPV for cash flows, both with list or matrix ...
Since you seem to be quite interested in financial calculations - maybe my program
TVM-Calc would be useful for you (at least to compare the results of your HP-Prime programs)?
It's about TVM and Cashflow calculations, and it has a lot of possible settings - you can find it on my website (and it's free!):
http://fhub.jimdo.com/
Franz
(05-20-2015 10:40 PM)fhub Wrote: [ -> ]Since you seem to be quite interested in financial calculations - maybe my program TVM-Calc would be useful for you (at least to compare the results of your HP-Prime programs)?
Franz
hi Franz!
Danke, thank you.
Very useful also your program.
I've downloaded and used it just now.
Salvo
hi,
you can find in the
HP Prime Software Library a much better version of the program, or ...two version: the first with the single functions exported (the user can recall them separately), the second with Drawmenu (every functions inside, but with a graphic interface).
I had to use a trick to avoid a strange erratic first argument output by solve() with the function for IRR, with a IRR value greater than 1 (100%) in some cases but not all...
irr:= solve(ΣLIST(MAKELIST((L1(I)/X^(I-1)),I,1,SIZE(L1))),X)-1;
IF (irr(1)>=1 OR irr(1)<=-1) THEN irr:=tail(irr); END;
// formula by akmon, Cyrille, Dale
please, control with examples, if possibles...
Enjoy!
Salvo
