05-17-2015, 06:24 PM
Link: http://edspi31415.blogspot.com/2015/05/h...usses.html
The following program, WTRUSS, calculates the upward forces of the truss’s pin and roller. The program allows for any number of beams (minimum of 1), however, all the beams have the same mass. The lengths between the pin, the beams, and the roller can vary.
Input:
h = height of the truss
l1, l2, l3, etc… = the lengths between each component
n = number of beams
m = mass of each beam
F = right-bound force from the truss
Output:
θ1, θ2, θ3, etc…. = angle from diagonal to peak, measured in degrees
E = upward force of the roller
B = upward force of the pin
WTRUSS works in two units sets: U.S. (feet, pounds, feet-pounds) and SI (meters, kilograms, Newtons).
Source:
Goswami, Indranil Ph. D. P.E. “All In One Civil Engineering PE Breadth and Depth” 2nd Edition McGraw Hill: New York. 2012. eBook.
Input:
n = number of beams
Output:
EXPORT WTRUSS()
// EWS 2015-05-04
// Warren Truss
LOCAL h,n,f,m,g,ch;
LOCAL l,t,c,s,k,a;
LOCAL m,E,B;
// Degree Mode
HAngle:=1;
CHOOSE(ch,"Unit System",
"FT-LB","KG-M");
IF ch==1 THEN g:=32.17405; END;
IF ch==2 THEN g:=9.80665; END;
INPUT({n,h,m,f},"Enter data",
{"n=","h=","m=","f="},
{"Number of beams","Height",
"Mass of beams","Force-Right"});
l:={};
FOR k FROM 1 TO n+1 DO
INPUT(s,"Length "+k,"k:");
l:=CONCAT(l,{s});
// Calculate Angles
a:=ATAN(h/(.5*l));
// Cumulative Lengths
c:=cumSum(l);
// Size
s:=SIZE(c);
t:=f*h+ΣLIST(m*g*SUB(c,1,s-1));
E:=t/c[s];
B:=n*g*m-E;
MSGBOX("Force at roller: "+E);
MSGBOX("Force at pin: "+B);
MSGBOX("Press return for a list of angles.");
RETURN a;
Source:
