05-16-2015, 10:18 PM
Hey, I've tried learning how to use the prime unit system properly but failed miserably.
I checked the user guide .pdf and they had an example:
Well, I tried this with the emulator and here's what happened:
Uhh, that's a bit weird, how about in the normal non-cas mode:
Seems to work fine, but wait! This works in cas mode:
That's a bit odd, isn't it?
Alright, well next up unit conversion.
CAS:
Fails, how about the non-cas mode?
Doesn't make any sense.
MKSA?
NOPE, works fine in normal non-cas though.
Same with USIMPLIFY..
So, why can I not use units properly in cas mode?
CAS:
MKSA?
