05-15-2015, 09:01 PM
Hi all,
here there is a program to calc chi2 test having only the variance s^2 and σ^2 (Test: H_0: σ^2 = value, H_1: σ^2 ≠ value), (i.e. s^2 = 0.0153, σ^2 = 0.01, n=20)
the test to confront with chi-square should be
\[ X_{0}^{2}= \frac{(n-1)s^{2}}{σ_{0}^{2}} \]
chi2_variance() calcs X² test and compare with χ² (saying if H₀ is to be reject or not), then calc also p value and confidence interval...
Enjoy!
Salvo Micciché
Enjoy!
Salvo Micciché
export chi_var_test:={"",0,"",0};
export chi_var_pvalue:=0;
export chi_var_dfreedom:=0;
export chi_var_intconf:={"", 0, "", 0};
EXPORT chi2_variance()
// Chi-square test for variances (H₀: σ²=σ₀² / H₁: σ² ≠ σ₀²)
local a:=0.05 ,n:=2, s:=1, si:=1, XT, chi, p;
local mesg, icl, icu, control:=1;
REPEAT
INPUT({a, n, s, si}, "Chi-square Variance test", {"Signif. level α=", "Sample size n=", "Sample var s²=", "Popul. var σ₀²="},
{"Significance level α (default 0.05)", "Sample size", "Observed Sample Variance s²", "Population Variation σ₀²"},{0.01, 2, 1, 1}, {a, n, s, si});
CASE
IF (a <=0 OR a>= 1) THEN MSGBOX("Significance level must be > 0 AND <1"); control:=1; a:=0.05; END;
IF (n<2) THEN MSGBOX("Sample numerosity must be >=2"); control:=1; n:=2; END;
IF (s<0) THEN MSGBOX("Sample Variance must be >= 0"); control:=1; s:=1; END;
IF (si<=0) THEN MSGBOX("Population Variance must be > 0"); control:=1; si:=1; END;
DEFAULT control:= 0;
END; // case
UNTIL control < 1;
XT:=((n-1)*(s))/(si); // test=(n-1)s²/σ²
chi:=chisquare_icdf(n-1,1-a);
p:= 1- chisquare_cdf(n-1, XT);
icl:= s*(n-1)/chisquare_icdf(n-1,1-a);
icu:= s*(n-1)/chisquare_icdf(n-1,a);
MSGBOX( "Test Hypothesis: H₀: σ²=σ₀² vs H₁: σ² ≠ σ₀²");
IF XT<chi THEN MSGBOX("Test X² < χ²: Fail to reject H0 at α=" + eval('a')); END;
IF XT >= chi THEN MSGBOX("Test X² > χ²: Reject H0 at α=" + eval('a')); END;
mesg:= "Degrees of freedom: "+ eval( '(n-1)');
MSGBOX(mesg);
sto({"X²", XT," χ²", chi}, chi_var_test);
sto(p, chi_var_pvalue);
sto(n-1, chi_var_dfreedom);
sto({"lower", icl, "upper", icu}, chi_var_intconf);
RETURN("Test XT=" + XT+" (χ²="+ chi + ") p=" + p);
