Full Version: Statistic Distributions
hi all,
with the new firmware 7820 some new statistic's distributions are been added to the Prime, a part of Normal, T (Student), F (Fisher), Chi square (χ2), Binomial, Poisson.
Now also other 8 from XCas: Beta, Cauchy, Exponential, Gamma, Geometric, NegBinomial, Uniform, Weibull. They are in Catalog (as normal form, cdf, icdf).
Other (and some alternative to those already in the Prime) can be found here in my programs.
If some of my functions should have the same name of those in the Prime, you can easily change the function's name in the code...
Logistic distribution
EXPORT logisticd(m,s,k)
// Logistic distribution m=μ location , s=σ >0 scale, k=x var
local f,g;
IF s<=0 THEN RETURN("Use: m, s>0, k"); END;
g:= (k-m)/s;
f:=e^(-g)/(s*(1+e^(-g))^2) ;
return f;
EXPORT logistic_cdf(m,s,k)
local f,g;
g:= (k-m)/s;
f := 1/(1+e^(-g));
return f;
END ;
EXPORT logisticd_icdf(m,s,p)
// inverse m=μ, s=σ, p probability
local f;
IF s<=0 THEN RETURN("Use: m, s>0, p"); END;
f:= m+s*ln(p/(1-p));
return f;
Lognormal
EXPORT LgNrm(m,s,k)
// LogNormal distribution m=μ, s=σ>0 shape, k=x var
local f;
f:= piecewise(k<=0,0, (1/(k*s*sqrt(2*pi)))*e^(-(ln(k)-m)^2/(2*s^2)));
return f;
EXPORT LgNrm_cdf(m,s,k)
// LgNrm(m,s,k) = normal((ln(k)-m)/s) - normal(k) = LgNrm(0,1,e^k)
local f;
f:=(1/2)+(1/2)*erf((ln(k)-m)/(sqrt(2)*s));
return f;
END ;
Exponential
EXPORT expond(l,n)
// exponential distribution l=λ=1/np, n
// expond(1/2, n) = chi2(2, n)
// expon(λ) = gammad2(1, 1/λ)
local f;
f:= piecewise(n<0,0,  l*e^(-l*n));
return f;
EXPORT expond_cdf(l,n)
local f;
f := piecewise(n<0, 0, 1-e^(-l*n));
return f;
END ;
Geometric
EXPORT geometric(p, k)
// Geometric distribution, k trial, p probability (kth trial first success)
// geometric(p) = Negbinom(1,p)
local f;
IF k<1 THEN RETURN("k must be int >= 1"); END;
k:= IP(k);
f:= p*(1-p)^(k-1);
return f;
EXPORT geometric2(p, k)
// Geometric distribution, k trial, p probability (failure until 1st success)
local f;
IF k<0 THEN RETURN("k must be int >= 0"); END;
k:= IP(k);
f:= p*(1-p)^(k);
return f;
EXPORT geometric_cdf(p, k)
local f;
f := 1-(1-p)^k;
return f;
END ;
EXPORT geometric2_cdf(p, k)
local f;
f := 1-(1-p)^(k+1);
return f;
END ;
Hypergeometric and negative hypergeometric
EXPORT hypergeom(N, n, m, k)
// Hypergeometric distribution
// N population size, m (or K) #successes in population
// n number of draws (without replacement), k (or i)  number of successes
local f;
f:= (comb(m,k)*comb(N-m,n-k))/(comb(N,n));
return f;
EXPORT negHypergeom(r, n, m, k)
// Negative Hypergeomtric distribution
// r nth special item, N=n+m, n special, m normal, k var
local f;
IF (k<r OR r<0 OR k<0) THEN RETURN("Use: (r, n, m, k) - k must be >= r"); END;
f:=(comb(n,r-1)*comb(m,k-r)/comb(n+m,k-1))*((n-r+1)/(n+m-k+1));
return f;
Negative Binomial
EXPORT NegBin(r, p,n)
// Negative Binomial distribution observing until r success, with p probability of success
//  n num trials for r success (k failures), n=r, r+1,...
// negBinom(1,p) = geometric(p)
local f;
IF (n<r) THEN return "n must be >= r"; ELSE
f:= comb(n-1, r-1)*(p^r)*(1-p)^(n-r);
return f;
END; //if
EXPORT NegBin_cdf(r, p, n)
local f, b1, a, b;
a:=r; b:= n+1;
b1:= int((X^(a-1))*(1-X)^(b-1),X,0,p);
// incomplete beta function
f:=( b1/Beta(a,b));
return f;
EXPORT NegBin2(r, p,k)
// Negative Binomial observing until r failures, with p probability of success (1-p failure)
// n num trials, k = n-r success
// i.e. NegBin(5,0.4,15) = NegBin2(5,0.6,10)
local f;
f:= (comb(k+r-1,k))*(p^k)*((1-p)^r);
return f;
Gompertz
EXPORT gompertz(h,b,n)
// Gompertz distribution h=η shape param, b scale param, n var
local f;
IF (n<0 OR h<=0 OR b<=0) THEN return "Not defined for η or b < =0 or n <0"; ELSE
f:= b*h*e^(b*n)*e^h*e^(-h*e^(b*n)) ;
return f;
END; // if
EXPORT gompertz_cdf(h,b,n)
local f;
f := 1-e^(-h*(e^(b*n)-1));
return f;
END ;
Weibull and Weibull translated
EXPORT weibull(k, l, t)
// Weibull distribution: l=λ>0 scale param (characteristic lifetime), k>0 shape parameter t var (time)
// weibull(λ,1) = exponential(1/λ), weibull(λ,2) = Rayleigh(λ/sqrt(2))
local f;
f:= piecewise(t<0,0,  (k/l)*(t/l)^(k-1)*e^(-(t/l)^k));
return f;
EXPORT weibull_cdf(k, l, t)
local f;
f:= piecewise(t<=0,0, 1-e^(-(t/l)^k)) ;
return f;
END ;
EXPORT weibull_translate(k, l, v, t)
// Weibull distribution translated: v (or θ theta) location parameter, normally 0
local f;
f:= piecewise(t<=v,0,  (k/l)*((t-v)/l)^(k-1)*e^(-((t-v)/l)^k));
return f;
EXPORT weibull_translate_cdf(k, l, v, t)
local f;
f:= piecewise(t<=v,0, 1-e^(-((t-v)/l)^k)) ;
return f;
END ;
Cauchy
EXPORT cauchyd(x0,g,n)
// Cauchy distribution x0 location param, g=γ scale param, n var
local f;
f:= 1/ (pi*g*(1+((n-x0)/g)^2)) ;
return f;
EXPORT cauchy_cdf(x0,g,n)
local f;
f:= (1/pi)*atan((n-x0)/g)+1/2 ;
return f;
END ;
EXPORT cauchy_icdf(x0,g,p)
// inverse x0, g=γ, p probability
local f;
f:= x0+g*tan(pi*(p-(1/2)));
return f;
Beta
EXPORT betad(a, b, n)
// Beta distribution: a=α>0, b=β>0 shape param, n var (0<=n<=1)
local f;
f:= piecewise(n<0 ,0, n>=1, 0, (1/Beta(a,b))*(n^(a-1))*(1-n)^(b-1));
return f;
EXPORT betad_cdf(a, b, n)
local f, b1;
b1:= int((X^(a-1))*(1-X)^(b-1),X,0,n);
f:=piecewise(n<0,0,n>=1, 0,  b1/Beta(a,b));
return f;
Gamma
EXPORT gammad(a,l,n)
// Gamma distribution 1st form a=α>0 shape param
//  l=λ>0 rate param, n var
// gammad::gamma2d α=k, β=1/θ
// gamma(1,1/λ) = expon(λ), gamma(n/2,1/2) = chi2(n)
local f;
f:= piecewise( n<0,0, (l*e^(-l*n)*(l*n)^(a-1))/Gamma(a)  );
EXPORT gammad_cdf(a,l,n)
local f;
f:= int(X^(a-1)*e^(-X),X,0,l*n)/Gamma(a);
return f;
END ;
EXPORT gammad2(k,t,n)
// Gamma distribution 2nd form  k>0 shape param,
// t=θ>0 scale param, n var
// if k is N (natural) -> Erlang distribution (k=1 -> exponential)
local f;
f:=piecewise(n<0,0,  (n^(k-1)*e^(-n/t)) / ((t^k) * Gamma(k)) );
return f;
EXPORT gammad2_cdf(k,t,n)
local f;
f:= int(X^(k-1)*e^(-X),X,0,n/t)/Gamma(k);
return f;
END ;
Zeta (Zpif)
EXPORT Zetazipf(s, k)
// Zeta (Zipf) distribution, not defined in s=1
local f;
IF s=1 THEN return "Not defined in s=1";  ELSE
f:= (k^(-s))/Zeta(s);
return f;
END;  //if
EXPORT Zetazipf_cdf(s,k)
local f, hks;
hks:= sum(1/(X^s), X, 1, k);
// nth generalized armonic number
f:= hks/Zeta(s);
return f;
Laplace
EXPORT laplaced(m,b,n)
// Laplace distribution m=μ location param, b scale param,  n var
// if m=0 and b=1 -> expond scaled by 1/2 (λ=1/b)
local f;
f:= (1/(2*b))*e^(-(ABS(n-m))/b);
return f;
EXPORT laplaced_cdf(m,b,n)
local f;
f := piecewise(n<m, (1/2)*e^((n-m)/b), 1-(1/2)*e^(-(n-m)/b));
return f;
END ;
Uniform distribution
EXPORT uniformd(a,b,n)
// Uniform, distribution [a-b], n var
local f:= piecewise(n>=a AND n<=b, 1/(b-a), 0);
return f;
EXPORT uniformd_cdf(a,b,n)
local f:= piecewise(n<a, 0, n≥b, 1, (n-a)/(b-a));
return f;
Multinomial distribution (requires n = total number of items, list of k items of a kind, list of their probabilities...)
EXPORT Multinomd(n, k, p)
// Multinomial distribution (n>0,{list k_i}, {list p_i})
IF ((type(k) ≠ 6) OR (type(p) ≠ 6)) THEN
return "2nd and 3th argument must be a list"; ELSE
IF n<1 THEN return "n must be >0"; END;
n:= ip(n); //n must be integer
IF (size(k) ≠ size(p) ) THEN return "items in k must be = those in p"; END;
IF (ΣList(k) ≠ n) THEN return "ΣList(k) must be = n"; END;
IF (ΣList(p) > 1) THEN return "ΣList(p) must be <= 1"; END;
// ΣList(p) should be = 1 but we can use in list k only values with no 0
//so items in p could be less than those in k...
return  (n!/ΠLIST(k!))*ΠLIST(p^k);
END; // if
n-Erlang distribution (see also Gamma and exponential)
EXPORT erlang(k,l,n)
// n-Erlang distribution k shape parameter, l=λ >=0 rate parameter
// from Gamma d.; if k=1 -> erlang(1,l,n) = exponential(l,n)
// erlang(k,λ) = gamma(k,1/λ)
local f;
f:=piecewise(n<0,0, l<0, 0, ((l^k)*(n^(k-1)*e^(-l*n)))/(k-1)! );
EXPORT erlang2(k, m, n)
//k shape parameter,  m=μ=1/λ >=0 scale parameter
// if μ=2 -> chi2 with 2k degree of freedom
local f;
f:=piecewise(n<0,0, m<0, 0, (n^(k-1)*e^(-n/m))/((m^k)*(k-1)!));
EXPORT erlang_cdf(k, l, n)
// k shape parameter, l=λ >=0 rate parameter (μ=1/λ)
local f;
f:= 1- sum((1/X!)*(e^(-l*n))*(l*n)^X,X,0,k-1);
Rayleigh distribution
EXPORT rayleigh(s, t)
// Rayleigh distribution s=σ scale parameter, t>=0 var
// rayleigh(2σ^2) = weibull(σ*sqrt(2),2)
local f;
f:= piecewise(t<0, 0, ((t/(s^2))*e^(-(t^2)/(2*(s^2)))));
return f;
EXPORT rayleigh_cdf(s, t)
local f;
f:= piecewise(t<0, 0, 1 - e^(-t^2/(2*(s^2))));
return f;
Pareto distribution
EXPORT paretod(xm, a, k)
// Pareto distribution x_m >0 scale, a=α > 0 shape
local f;
IF ((a<=0) OR (xm <= 0) OR (k<xm)) THEN RETURN("Use: xm > 0, a >0, k >= xm"); END;
f:=(a*xm^a)/k^(a+1);
return f;
EXPORT paretod_cdf(xm, a, k)
local f;
f:=1-(xm/k)^a;
return f;
EXPORT paretod_bound(a, L, H, k)
// Bounded Pareto distribution
// a=α >0 shape, L>0, H>L location, k var
local f;
IF (a<=0 OR L<=0 OR H<=L) THEN RETURN("Use a>0, L>0, H>L"); END;
f:= (a*L^a*k^(-a-1))/(1-(L/H)^a);
return f;
EXPORT paretod_bnd_cdf(a,L,H,k)
local f;
f:= (1-L^a*k^(-a))/(1-(L/H)^a);
return f;
The important and classic Maxwell-Boltzmann Distribution
EXPORT maxwell_boltzmannd(a, n)
// Maxwell-Boltzmann distribution
// scale parameter a = SQRT(kT/m), k=Boltzmann constant
// chi2 with 3 DF
local f;
f:=piecewise(a<0, 0, sqrt(2/PI)*((n^2)*e^((-n^2)/(2*a^2)))/(a^3)  );
return f;
EXPORT maxwell_boltzman_cdf(a, n)
// chi2 with 3 DF
local f;
f:=piecewise(a<0, 0, erf(n/(sqrt(2)*a) )- (sqrt(2/PI))*(n*e^((-n^2)/(2*a^2)))/a  );
return f;
Enjoy with Statistic in the Prime!
Salvo Micciché
Gumbel (and Standard Gumbel) distribution
EXPORT gumbel(m,b, k)
// Gumbel distribution m=μ location, b=β>0 scale, k=x var
// also log-Weibull
local f, z;
IF b<=0 THEN RETURN("Use: m, b>0, x"); END;
z:= (k-m)/b;
f:= (1/b)*e^-(z+e^-z);
RETURN f;
EXPORT gumbel_cdf(m,b,k)
local f;
f:= e^-(e^(-(k-m)/b));
EXPORT gumbel_std(k)
// Standard Gumbel distribution
// (m=μ location, b=β>0 scale, k=x var)
// μ=0 and β=1
local f;
f:= e^-(k+e^-k);
RETURN f;
EXPORT gumbel_std_cdf(k)
local f;
f:= e^-e^(-k);
Fréchet Distribution (also inverse Weibull)
EXPORT frechet(a,s,m,k)
// Fréchet distribution
// also inverse Weibull
// a=α>0 shape, s>0 scale (default 1)
// m localtion of minimum (default 0)
// k=x var
local f;
IF a<=0 OR s<=0 THEN RETURN("Use: a>0, s>0, m[def 0], x"); END;
f:= (a/s)*((k-m)/s)^(-1-a)*e^(-((k-m)/s)^(-a));
RETURN f;
EXPORT frechet_cdf(a,s,m,k)
local f;
f:= e^(-((k-m)/s)^(-a));
RETURN f;
