05-14-2015, 02:50 PM
Edit: Programme changed to remove uncommon names for pointers etc.
The built in integer square root-finder function returns the integer square root of N a positive integer & TRUE/FALSE if the square of the answer is exactly N or not. Sadly the square root of larger integers is not calculated correctly.
eg For entry
8057607683965968206853219945486680251051474004852138
FPTR2^ZSQRT returns
89764178177967899999999999 (incorrect value) & FALSE.
The programme below returns
89764178177967898147413811 (correct value) & FALSE.
Programme name: ISQRT
CkSum: # 6291d
eg For entry
FPTR2^ZSQRT returns
CkSum: # 6291d
CK1&Dispatch
# FF
DUP
ZINT 2
Z<
DUP
?SEMI
DROPDUP
FPTR2 ^Z>ZH
FPTR2 ^ZBits
BINT2
ZINT 2
SWAP
FPTR2 ^PPow#
SWAPDROPDUP
3PICKOVER
FPTR2 ^ZQUOText
FPTR2 ^QAdd
ZINT 2
FPTR2 ^ZQUOText
2DUP
Z>
NOT_UNTIL
DROPDUP
DUP
FPTR2 ^QMul
ROT
EQUAL
