05-14-2015, 01:27 PM
Hello
I have a problem using the INPUT command in RPN mode : In a simple program like this :
When I try to enter a negative number for A or B, Something strange happens : Single quotes are added in the edit line around my number and when I press OK, I have an Invalid Entry error. If I remove single quotes around my number, then it is OK. With positive numbers, no problem.
When I am in textbook or algebraic mode, I have no such problem.
I use the latest firmwrare (05/2015) but the problem was here also with the previous ones.
Quote:EXPORT TEST()
INPUT({A,B});
