05-14-2015, 11:16 AM
edit with some comments on the code and the attachment file first forgot...
Few time ago I wrote an basic custom App for BODE plot based on FUNCTION APP... On the physical prime [FW7820] no problem, everything works like before. But on the new emulator ( new FW 7820 ) the plot view seem to be dead, unresponsive... I can't use these app on emulator...
If someone have an idea... and time to look at...
I know my code is perhaps not readable (french language inside I know is not a good idea for worldwide exchange :o).
Usage is very basic: Place your transfert function (in term of X) in symb view. Transfer functions must be write without float numbers. F1(X)=1/(1+0.2*X) doesn't works... but F1(X)=1/(1+1/2*X)^2 is ok...
In SYMB view you can place 1 to 10 transfer functions in term of 'X', example:
Actually the exponential term must be at the end of the expression (see the example above) not very powerful but it do the job to model a pure delay.
Then press PLOT to choose step response (here occur the problem on emulator) , Bode module or Bode phase (x axis is in term of LOG10(pulsation)) . There is no automatic scale.
You have to escape from plot view (pressing num or symb again) if you want to choose another plot...
If you find some time I would like to learn and improve my practice through constructive criticism ... Thanks ;o)
In attach file you will find the binary version of the app...
here is the code:
F1(X)=(1+2*X)/(1+2*X+1/10*X^2)^2*e^(-2*X)
here is the code:
copie_les_fonctions(); //copy transfert func from SYMB view to liste_fonctions
replace_les_fonctions(); //copy transfert func from liste_fonctions to SYMB view
place_les_modules(); //copy magnitude expressions from liste_modules to SYMB
place_les_phases(); //copy phase expressions from liste_phases to SYMB
place_les_rep_temp(); //copy step resp expressions from liste_rep_temp to SYMB
calcule_modules(); // expressions magnitudes calculation
calcule_phases(); // calc phases expressions
calcule_rep_temp(); // calc step response expressions
Symb();
export liste_fonctions:=MAKELIST(0,X,1,10); //copy of transfert func
export liste_modules:={}; // magnitude expr when calculated are there
export liste_phases:={}; // phase expr are save here
export liste_rep_temp:={}; // step resp expr are here
recalc_module:=MAKELIST(1,X,1,10); // flag are set to 1 if recompute is need for magnitude
recalc_phase:=MAKELIST(1,X,1,10); // flag if phase recompute
recalc_temp:=MAKELIST(1,X,1,10); // flag if step resp need to be recompute
modif:=0; // if the user come on symb view these flag tell that some modifications may occur on transfert expr
begin
local k;
for k from 1 to 10 do
if ISCHECK(k MOD 10) then
if EVAL(EXPR("F"+k MOD 10)≠liste_fonctions(k)) then
IFERR liste_fonctions(k):=EXPR("F"+k MOD 10) then MSGBOX("Erreur de copie sur F"+k MOD 10) end;
recalc_module(k):=1;
recalc_phase(k):=1;
recalc_temp(k):=1;
end;
end;
end;
modif:=0;
end;
begin
local k;
for k from 1 to length(liste_fonctions) do
expr("F"+k MOD 10+":=liste_fonctions("+k+")");
end;
end;
end;
place_les_modules()
begin
local k;
for k from 1 to length(liste_modules) do
expr("F"+k MOD 10+":=liste_modules("+k+")");
end;
end;
end;
place_les_phases()
begin
local k;
for k from 1 to length(liste_phases) do
expr("F"+k MOD 10+":=liste_phases("+k+")");
end;
end;
end;
begin
local k;
for k from 1 to length(liste_rep_temp) do
expr("F"+k MOD 10+":=liste_rep_temp("+k+")");
end;
end;
end;
calcule_modules()
begin
local k;
if ISCHECK(k MOD 10) AND recalc_module(k) then
liste_modules(k):=20*LOG(ABS(subst(liste_fonctions(k),'X','i*ALOG(X)')));
recalc_module(k):=0;
end;
end;
end;
calcule_phases()
local k,j,r,retard;
local f, a,num,denomi,cnum,cdenom,phi;
if ISCHECK(k MOD 10) AND recalc_phase(k) then
f:=replace(string(liste_fonctions(k)),"X","x");
r:=instring(f,"e");
if r then
retard:=right(f,size(f)-1-r);
f:=left(f,r-2);
end;
a:=CAS.froot(f,"x");
num:=string(CAS.numer(f));
denomi:=string(CAS.denom(f));
cnum:=CAS.lcoeff(num,"x");
cdenom:=CAS.lcoeff(denomi,"x");
phi:=string(ARG(cnum/cdenom));
FOR j FROM 1 TO length(a) STEP 2 DO
IF RE(a(j))<>0 THEN
phi:=phi+"+"+a(j+1)+"*ATAN(("+IM(a(j))+"-X)/("+RE(a(j))+"))";
ELSE IF a(j)==0 THEN
phi:=phi+"+"+a(j+1)+"*90";
ELSE phi:=phi+"+"+a(j+1)+"*90*SIGN(X-"+IM(a(j))+")";
END; //fin IF
END; //fin FOR j
if r then phi:=phi+"+"+replace(retard,"x","X") end;
phi:="'"+replace(phi,"X","ALOG(X)")+"'";
liste_phases(k):=EXPR(phi);
recalc_phase(k):=0;
end; //fin if ischek
end; //fin for k
calcule_rep_temp()
begin
local f, k;
if ISCHECK(k MOD 10) AND recalc_temp(k) then
f:=REPLACE(STRING(liste_fonctions(k)),"X","x");
f:=f+"*1/x,x,x";
f:="'("+REPLACE(STRING(CAS.ilaplace(f)),"x","X")+")*PIECEWISE(X<0,0,X≥0,1)'";
IF instring(f,"ilaplace")
THEN MSGBOX("Problème avec F"+k MOD 10); CONTINUE;
ELSE liste_rep_temp(k):=EXPR(f);
recalc_temp(k):=0;
end;
end;
end;
Symb()
begin
modif:=1;
replace_les_fonctions;
STARTVIEW(0,1);
end;
Plot()
begin
local choix;
if modif then copie_les_fonctions end;
CHOOSE(choix,"Choisissez un type de tracé",{"Module","phase","réponse indicielle"});
CASE
IF choix==1 THEN calcule_modules; place_les_modules;Ytick:=20 END;
IF choix==2 THEN calcule_phases; place_les_phases;Ytick:=45 END;
IF choix==3 THEN calcule_rep_temp; place_les_rep_temp; Xmin:=−0.2 END;
//DEFAULT
STARTVIEW(1,1);
end;
START()
begin
STARTVIEW(0,1);
end;
