05-05-2015, 03:47 PM
MFUN applies a function to a square matrix, calculator should be in approx & complex modes. For example, to find the natural log of matrix
M1=[[ -9. 0. -1. -4. ]
[ 4. 9. 3. 3. ]
[ 0. 4. -9. 9. ]
[ 5. -1. -6. -4. ]]
place M1 on stack level Y & 'LN(X)' on stack level X. MFUN returns the complex matrix
M2=[[ (2.17927367373,1.99350072846) (-.185449038469,-.25062812471) (.12978172209,1.13653167793) (-1.21072226166,-.24561453301) ]
[ (-.349990278973,-.725022350755) (2.17006519946,9.11517059164E-2) (.316994726521,-.413348667032) (-8.29926914019E-3,8.93282974816E-2) ]
[ (.499972969813,1.87320392796) (.360844076572,-.235504096367) (1.81399293871,1.06794824449) (2.26427803714,-.230793047339) ]
[ (1.5738586231,8.93453089839E-2) (.311847366461,-1.12327258886E-2) (-1.58567642989,5.09374150115E-2) (2.97368489567,-.011008025242) ]]
to stack level X.
As a check, you could then put 'e^X' on the stack & actuate MFUN again, to return
[[ (-8.99999999989,-1.62595437076E-10) (-7.789692811E-12,2.87950512152E-11) (-.999999999977,-1.80997814311E-10) (-3.99999999999,-1.76112719874E-11) ]
[ (3.99999999998,4.21474277251E-11) (9.00000000017,7.44661562123E-11) (2.99999999996,3.96498859739E-11) (3.00000000004,1.34469661894E-12) ]
[ (2.98413096713E-11,-1.53814112532E-10) (3.99999999998,4.04329178333E-11) (-8.99999999998,-1.19988781132E-10) (8.99999999994,1.82967287016E-10) ]
[ (4.99999999998,6.94233268647E-11) (-1.00000000004,6.827569037E-12) (-5.99999999997,-5.4121217567E-11) (-4.00000000003,1.19154531002E-10) ]]
where the imaginary parts are v small, so RE 0 RND looks more like the original M1.
I am sure the programme has enormous inefficiencies & would welcome improvements.
TI fans - the TI-92 does this out of the box, just use LN(M1).
[ 4. 9. 3. 3. ]
[ 0. 4. -9. 9. ]
[ 5. -1. -6. -4. ]]
to stack level X.
CK2&Dispatch
# 49
Z1_
Z0_
NULL{}
DUPDUP
BINT1
BINT1
BINT0
FPTR2 ^RCLVX
NULLLAM
BINT11
NDUPN
DOBIND
BINT105
BINT110
ClrUserFlag
ClrUserFlag
BINT110
BINT110
SysITE
SetUserFlag
SetSysFlag
BINT105
BINT105
SysITE
SetUserFlag
11GETLAM
FPTR2 ^CKNUMARRY
11PUTLAM
DROP
11GETLAM
DUP
MDIMSDROP
DROP
4PUTLAM
FPTR2 ^MATEGVL
FPTR2 ^MATRIX2LIST
DUPLENCOMP
4GETLAM
IT
BINT105
SetSysFlag
DROP
11GETLAM
FPTR2 ^CKNUMARRY
DUP
11PUTLAM
FPTR2 ^MATEGVL
FPTR2 ^MATRIX2LIST
7PUTLAM
4GETLAM
#0<>
WHILE
6GETLAM
7GETLAM
CARCOMP
>TCOMP
DUP
6PUTLAM
5GETLAM
BINT1
>TCOMP
5PUTLAM
3GETLAM
NTHCOMPDROP
7GETLAM
CDRCOMP
DUP
7PUTLAM
SWAP
EQUALPOSCOMP
2PUTLAM
2GETLAM
#0<>
WHILE
7GETLAM
INNERDUP
#2+
2GETLAM
ROLLDROP
#1-{}N
DUP
7PUTLAM
5GETLAM
DUP
3GETLAM
NTHCOMPDROP
#1+
3GETLAM
ROT
PUTLIST
5PUTLAM
6GETLAM
3GETLAM
NTHCOMPDROP
EQUALPOSCOMP
2PUTLAM
REPEAT
3GETLAM
#1+
3PUTLAM
7GETLAM
LENCOMP
4PUTLAM
REPEAT
3GETLAM
#1-
3PUTLAM
11GETLAM
MDIMSDROP
DROP
4PUTLAM
9GETLAM
4GETLAM
ONE_DO
1GETLAM
INDEX@
FPTR2 ^#>Z
PTR 2EF1F
>TCOMP
LOOP
10GETLAM
>TCOMP
DUP
9PUTLAM
1GETLAM
6GETLAM
CARCOMP
PTR 2EF27
FPTR2 ^FLAGSYMBEXEC
FPTR2 ^LIST2MATRIX
5GETLAM
CARCOMP
BINT1
IT
5GETLAM
CARCOMP
ONE_DO
9GETLAM
INDEX@
ZERO_DO
1GETLAM
FPTR2 ^DERIVext
LOOP
1GETLAM
6GETLAM
CARCOMP
PTR 2EF27
xSUBST
xAXL
LOOP
3GETLAM
BINT1
IT
3GETLAM
#1+
BINT2
DO
9GETLAM
1GETLAM
6GETLAM
INDEX@
NTHCOMPDROP
PTR 2EF27
FPTR2 ^FLAGSYMBEXEC
FPTR2 ^LIST2MATRIX
5GETLAM
INDEX@
NTHCOMPDROP
BINT1
IT
5GETLAM
INDEX@
NTHCOMPDROP
ONE_DO
9GETLAM
INDEX@
ZERO_DO
1GETLAM
FPTR2 ^DERIVext
LOOP
1GETLAM
6GETLAM
JINDEX@
NTHCOMPDROP
PTR 2EF27
xSUBST
xAXL
LOOP
LOOP
4GETLAM
FPTR 3 68
FPTR2 ^MATRREF
4GETLAM
#1+
FPTR2 ^MATRIX-COL
SWAPDROP
FPTR2 ^MATRIX2LIST
DUP
8PUTLAM
CARCOMP
4GETLAM
UNCOERCE
PTR 2F28F
FPTR2 ^SCL*MAT
4GETLAM
#1+
BINT2
DO
8GETLAM
INDEX@
NTHCOMPDROP
11GETLAM
INDEX@
#1-
FPTR2 ^#>Z
FPTR2 ^MAT^
FPTR2 ^SCL*MAT
FPTR2 ^MAT+
LOOP
ABND
FPTR2 ^FLAGEXPAND
BINT110
BINT110
UserITE
ClrUserFlag
ClrSysFlag
BINT105
BINT105
UserITE
ClrUserFlag
ClrSysFlag
