04-25-2015, 06:58 AM
Below a programme to convert negadecimal base numbers to decimal.
The advantage of negadecimal base is that there is no need for a negative sign. Indeed, the old problem of the existence of negative numbers disappears as they become interleaved with the positives. & what happens to the question of sign? The notational resolution of these two bugbears of traditional numeration is surely of some utility.
Reading the digits of a negadecimal number from right to left, they represent
units, negative tens, hundreds, negative thousands, ten thousands,......
eg Negadecimal 36123 is 3+2*(-10)+1*(100)+6*(-1000)+3*(10000), or base 10 24083.
Similarly, 1066 negadecimal becomes -1054 decimal.
For conversion decimal to negadecimal programme see:
http://oeis.org/A256639
CK1&Dispatch
# FF
ZINT -10
1LAMBIND
FPTR2 ^DupZIsNeg?
SWAP
FPTR2 ^ZABS
Z1_
Z0_
ROT
FPTR2 ^DupQIsZero?
NOT_WHILE
ZINT 10
FPTR2 ^ZDIVext
4ROLL
DUP
1GETLAM
FPTR2 ^RMULText
5UNROLL
FPTR2 ^RMULText
ROT
FPTR2 ^RADDext
SWAP
REPEAT
ABND
DROPSWAPDROP
SWAP
case
FPTR2 ^RNEGext
CK1&Dispatch
# FF
ZINT -10
1LAMBIND
FPTR2 ^DupZIsNeg?
SWAP
FPTR2 ^ZABS
Z1_
Z0_
ROT
FPTR2 ^DupQIsZero?
NOT_WHILE
ZINT 10
FPTR2 ^ZDIVext
4ROLL
DUP
1GETLAM
FPTR2 ^RMULText
5UNROLL
FPTR2 ^RMULText
ROT
FPTR2 ^RADDext
SWAP
REPEAT
ABND
DROPSWAPDROP
SWAP
case
FPTR2 ^RNEGext
