Inspired by the proposal of John A. Ball in his book ‘Algorithms for RPN Calculators’, as a proof of concept I implemented a stack overflow sensing (SOS) scheme using Neil Fraser's JavaScript HP-35 simulator.
In the process I made my own ‘Red Dot’ HP-35 calculator ;-)
Have a look
here and see for yourself if HP missed a chance to build SOS into its very first pocket calculator (and, incidentally, into all its subsequent classical RPN models).
Hans
P.S.: I discovered a small inaccuracy in the functioning of the π-key of the original HP-35 simulator and corrected it in the HP-35 SOS.
(04-16-2015 11:08 PM)hansklav Wrote: [ -> ]Inspired by the proposal of John A. Ball in his book ‘Algorithms for RPN Calculators’, as a proof of concept I implemented a stack overflow sensing (SOS) scheme using Neil Fraser's JavaScript HP-35 simulator.
Have a look here and see for yourself if HP missed a chance to build SOS into its very first pocket calculator (and, incidentally, into all its subsequent classical RPN models).
Hans
This is interesting. As I understood you made patches of the original HP-35 firmware. Do you think it could be possible to make further changes like adding new functions, making the HP-35 a programmable calculator, or write a compiler for ACT firmware?
Bernhard
Thanks Thomas for clarifying this.
As I understand now, this HP-35 simulator does not emulate the original HP-35 firmware.
Bernhard
(04-18-2015 03:55 PM)PANAMATIK Wrote: [ -> ]As I understand now, this HP-35 simulator does not emulate the original HP-35 firmware.
You’re quite right: Neil Fraser’s JavaScript HP-35 simulator doesn’t emulate the HP-35
firmware but it does emulate its external behaviour. My modification of it (the ‘HP-35
SOS’) adds one feature,
Stack
Overflow
Sensing (SOS) to show how this could work out for the user of a classical RPN calculator.
You can download the source code (or simply study it from within your webbrowser); I documented all the added/modified lines.
Hans
