hi everybody,
I didn't find in the PDF Guide the default value for the CAS Settings values on page 2 (Recursive evaluation, replacement, function, epsilon, probability, newton)
Are they the same for Emulator and the Prime?
Sure I made sono tries and now they are different.
There is a way to get the default values with our reset the calculator?
Thanks!
salvo
auto-reply :-)
found!
CAS Settings (shift CAS), then shift+Esc (Clear)
Recursive evaluation 5
recursive replacement 1
recursive function 100
Epsilon 0.000000000001
Probability 1E-15
Newton 60
Aren't they?
(04-14-2015 07:58 PM)salvomic Wrote: [ -> ]auto-reply :-)
found!
Probability 1E-15
Newton 60
Aren't they?
Strange to tell, the
original defaults (in a brand-new machine, or after a total memory reset) are slightly different from the Shift Esc (Clear) values:
After total memory reset: 5, 1,
9, 1e-12, 1e-15,
40.
After Shift Esc (Clear): 5, 1,
100, 1e-12, 1e-15,
60.
The "total memory reset" values also seem to reappear after an Apps+Esc+On warmstart, which may or may not perform a total memory reset, depending on your firmware version, the phase of the moon, and Murphy's Law.
(04-15-2015 04:47 AM)Joe Horn Wrote: [ -> ]Strange to tell, the original defaults (in a brand-new machine, or after a total memory reset) are slightly different from the Shift Esc (Clear) values:
After total memory reset: 5, 1, 9, 1e-12, 1e-15, 40.
After Shift Esc (Clear): 5, 1, 100, 1e-12, 1e-15, 60.
I don't know, Joe, it's a mystery also for me...
between 9 and 100 there is *only* a little difference ;-)
So which values are the most suitable?
Salvo
