04-13-2015, 08:14 PM
\[\frac{1}{\sqrt{1}}+\frac{1}{\sqrt{2}}+\frac{1}{\sqrt{3}}+\frac{1} {\sqrt{4}}+\frac{1}{\sqrt{5}}+\cdots+\frac{1}{\sqrt{n}}\]
Write an HP-71B BASIC program and use it to evaluate the sum above when n = 10¹². The program must fit in one line. Accuracy in the widest range as
possible is desirable, but if you manage to show 12 correct digits for that particular required n, then it is ok. I will present an 80-character long
program that gives accurate results for n as low as 30, in less than 300 milliseconds.
This can be extended to other HP calculators and the WP-34S as well. As a reference, a 21-step program on the latter gives 12 accurate digits when n =
30 and 33 or 34 correct digits for n around 100000 and greater.
Have fun!
Gerson.
EDITED TO CHANGE THE SUBJECT TITLE AS THE MATH ROM IS NOT REQUIRED.
Have fun!
Gerson.
