hi all,
sorry if I repost a question:
I'm trying to upgrade my program to calculate the Fourier's Coefficient, it's a #cas/#end program, with a function (ChooseInterval()) to choose value for integral's interval.
At the moment it has two options ([0, 2PI] - [-PI, PI]), now I'm adding another option to enclose the case "Other", to calculate any interval.
But now (for case 3) I need to input two values for inf and sup values of interval.
I'm trying:
INPUT({low,hi}, "Interval",{"lower limit", "upper limit"}, {"input lower limit", "input upper limit"}, {0,2});
It works with a "Home" program, but not here: I get "Error: Invalid input"...
Any help?
Salvo
(04-10-2015 07:45 PM)salvomic Wrote: [ -> ]hi all,
I'm trying:
Any help?
Salvo
From
http://www.hpmuseum.org/forum/thread-359...l#pid32427 :
Non-CAS programs can make use of "interface" commands such as CHOOSE() and INPUT() whereas CAS programs are generally not interactive. A workaround is to use the EXPR() command to call these commands indirectly. EXPR() works like CAS() in that both take input strings.
(04-10-2015 08:55 PM)Han Wrote: [ -> ]Non-CAS programs can make use of "interface" commands such as CHOOSE() and INPUT() whereas CAS programs are generally not interactive. A workaround is to use the EXPR() command to call these commands indirectly. EXPR() works like CAS() in that both take input strings.
do you mean something like this?
EXPR(INPUT(T, "Period","period T", "input period T", 2));
(04-10-2015 09:08 PM)salvomic Wrote: [ -> ] (04-10-2015 08:55 PM)Han Wrote: [ -> ]Non-CAS programs can make use of "interface" commands such as CHOOSE() and INPUT() whereas CAS programs are generally not interactive. A workaround is to use the EXPR() command to call these commands indirectly. EXPR() works like CAS() in that both take input strings.
The argument for EXPR() must be a string such that, when parsed, is equivalent to the command you wish to issue.
