The HP Prime program CENTERMTX calculates the center of mass of the matrix M, where M represents the body. The entries of M represents an array of molecules, each with assigned weights. It is possible that the center of mass is located outside of the body.
Note: If gravity affects the particles equally, then the center of mass & center of gravity are identical.
Formulas:
Xc = ∑(x * m)/∑m
Yc = ∑(y * m)/∑m
HP Prime: CENTERMTX
EXPORT CENTERMTX(m)
// Center of Mass: matrix
// Matrix of mass
LOCAL s,tm,rt,ct,r,c;
// in MAKEMAT I=row,J=col
s:=SIZE(m);
r:=s(1);
c:=s(2);
// Total Mass
tm:=TRN(m*MAKEMAT(1,c,1))*
MAKEMAT(1,r,1);
tm:=tm(1,1);
// Row Total
rt:=TRN(m*MAKEMAT(I,c,1))*
MAKEMAT(1,r,1);
rt:=rt(1,1);
// Column Total
ct:=TRN(TRN(m)*MAKEMAT(I,r,1))*
MAKEMAT(1,c,1);
ct:=ct(1,1);
// center
RETURN [[rt/tm,ct/tm]];
Example: Locate the center of mass of the following body.
M = [[1 , 2, 1], [1, 1, 2],[1, 2, 1]]
The center of mass: [[ 2.08333333333, 2 ]]
http://edspi31415.blogspot.com/2015/04/h...atrix.html
Congrats for your program, I´m going to download to my calculator. This is the first step for simebody who wants to program the famous and impressive "Sección" program for HP48 or 50, with gravity center, moments of inertia etc, on any shape, any.
(04-05-2015 10:29 PM)akmon Wrote: [ -> ]Congrats for your program, I´m going to download to my calculator. This is the first step for simebody who wants to program the famous and impressive "Sección" program for HP48 or 50, with gravity center, moments of inertia etc, on any shape, any.
I quote!
thank you, Eddie
Salvo
I´ve tried a little example to manage the program, but I didn´t get the results I expected. I want to know the center of gravity of a triangle. The coordinates are (0,0), (5,0) and (5,5). I suppose mass 1 for every points, so I write this matrix:
[[0 0 1][5 0 1][5 5 1]]
The gravity center sould be (10/3 5/3), but I don´t get that result. What am I doing bad? Thank you.
(04-07-2015 06:33 AM)akmon Wrote: [ -> ]I´ve tried a little example to manage the program, but I didn´t get the results I expected. I want to know the center of gravity of a triangle. The coordinates are (0,0), (5,0) and (5,5). I suppose mass 1 for every points, so I write this matrix:
Note that the matrix does
not contain the coordinates and associated masses, but rather it's a grid representation of point masses. There is an explanation of the matrix in
Eddie's blog.
For your example the matrix may be entered as (6x6 matrix, e.g. 0 to 5 = 6 grid points):
[[1 0 0 0 0 1][0 0 0 0 0 0][0 0 0 0 0 0][0 0 0 0 0 0][0 0 0 0 0 0][0 0 0 0 0 1]]
This will yield the center of mass at grid position (13/3 8/3), having a (+1 +1) offset with respect to your solution (note that the origin (0 0) is at grid position (1 1)).
The following program computes the center of mass for arbitrary arrangements of mass points in 3D cartesian space. For a system consisting of n particles the input is a n-by-4 matrix, e.g. the x, y, z coordinates in the the first three columns and the masses in the forth column.
EXPORT CG(xyzm)
LOCAL s,r,c,t,x,y,z,m;
LOCAL mt,cx,cy,cz;
s:=SIZE(xyzm);
r:=s(1);
c:=s(1);
t:=TRN(xyzm);
x:=t(1);
y:=t(2);
z:=t(3);
m:=t(4);
mt:=ΣLIST(m);
cx:=DOT(x,m)/mt;
cy:=DOT(y,m)/mt;
cz:=DOT(z,m)/mt;
RETURN [[cx,cy,cz]];
Using akmon's example:
CG([[0 0 0 1][5 0 0 1][5 5 0 1]]) = [3.333333333 1.666666667 0] = [10/3 5/3 0]
Thank you very much for your version, Thomas. That´s what I was searching, easier for matrix input, even I edited it simpler, because 99% I work in 2D only.
There is built-in function in HP Prime for this.
attachment=2258] [
attachment=2259]
