Hi Everyone!!
I guess I need a little bit of help on the syntax of the INPUT command. I'm trying to create some sort of drop-down menu, so I can choose an option.
I read the UG. and the built-in help on the calculator, I entered the corresponding code for that, and I'm still getting an error message. ("see screenshot # 1")
I'm trying to create something like the screenshot # 2 & 3.
here is my code:
EXPORT program()
INPUT({D,{"OPTION 1","OPTION 2","OPTION 3","OPTION 4"},{20,70,3}},{"Main title"},{"LABEL"},{"HELP 1","HELP 2","HELP 3","HELP 4"},0,0);
Thanks, any help will be appreciated.
attachment=1827] [
attachment=1828] [
attachment=1829]
Two things. You are attempting to create a field for variable D, and then a non-existent type. Look at your variable list: {
D,
{"Strings"...
Also, you are defining help strings for 4 fields.
EXPORT program()
INPUT({{D,{"OPTION 1","OPTION 2","OPTION 3","OPTION 4"},{20,70,3}}},"Main title","LABEL","HELP 1",0,0);
Adding { } around the title field and similar is for additional pages of your input form. If you have one, no need to have it.
Thank You Tim.
I notice something in the piece of code you wrote:
{{D,{"OPTION 1","OPTION 2","OPTION 3","OPTION 4"},{20,70,3}}} ...
In this line, it seems to me that there is an extra pair of brackets {}, so I took them out and ran the program, I realized that it didn't run!, so I put them back in place and it worked again. my question is why an extra pair of brackets make the difference?
To define a choose in an an input form, you create a list of the form {var,{"choices"...}}.
{ A,B,{C,{"choices"...}} } is 3 objects, A, B and a choose object. Doing {D,{"choices"...} has made one real input D, and then an invalid input item - hence the error.
That make sense Tim, Thank you for your answer.
