hi,
why I get error with this code?
myvar:= Statistic_2var.MeanY;
but not with
myvar:= Statistic_2var.Resid();
// or myvar:= Resid();
if I type "Statistic_2var.MeanY" in CAS or Home it's ok, but I get error in a program...
where I'm wrong?
thank you in advance,
Salvo
Mine reboots if I eval Statistic_2var.MeanY in home
This is probably obvious, but what I have found so far on the Android emulator:
The App is statistics with an s: Statistics_2Var
If you select the variables from the toolbox/App/Statistics_2Var,
Resid is listed but MeanY is not.
Suggesting that perhaps that variable is not defined in that App. I also tried1Var: same .
But typing it in at Home gives Error: Insufficient data (I haven't set any up), meaning Home recognises MeanY.
Update: But then I re-edited my program changing 1Var.MeanY back to 2Var.MeanY - and now it compiles! So: Did I have a typo earlier? Or did the Home evaluation change something?
EXPORT TR()
PRINT(Statistics_2Var.MeanY);
PRINT(Statistics_2Var.Do2VStats());
WAIT;
You may have ran into the same problem I ran into. It depends on the mode type used. In any case you can review what I posted as a possible work around. Please review the following thread.
http://www.hpmuseum.org/forum/thread-5111.html
Michael
