After renaming a column in the spreadsheet, e.g. the first column from ‘A’ to ‘Alpha’, it seems impossible to change the name back to ‘A’. There is only a message “Error: Invalid input”. Is there a simple workaround?
(03-19-2015 05:27 PM)Dirk. Wrote: [ -> ]After renaming a column in the spreadsheet, e.g. the first column from ‘A’ to ‘Alpha’, it seems impossible to change the name back to ‘A’. There is only a message “Error: Invalid input”. Is there a simple workaround?
Select the cell and press DEL
Thank you very much!
Not intutive to me, but very simple and working. And it does not delete the contents of the whole column.
