03-18-2015, 08:48 PM
Request: Toolbar
Hello, sorry for my bad English
For the team hpprime, is required a toolbar to create good programs with GUI
an example code of series ti68k calcs
![[Image: AnimationOfPolyhedrons.png]](http://www.jaimeza.org/Mathematic/TexasInstruments/ti68k/graphics/images/AnimationOfPolyhedrons.png)
Survey is important to have a block of statements for this purpose?
+1
animTbar()
Prgm
© animTbar(): Animations Toolbar
Local chspolvl, chsplvl1
Loop
putbar({},0)
Toolbar
Title "Polyhedron"
Item "Regular Polyhedron",regpollb
© regular, convex polyhedron with congruent faces of regular polygons
Item "Other important polyhedra",othrpolb
Title "Paramts"
Item "Set parameters page1/2",wparamlb
Item "Parameters page2/2",wparm2lb
Item "Parameters 3",wparm3lb
Item "Default values",dftparlb
Title "MakeImag",makeimlb
Title "Animation",startalb
Title "Delete Images"
Item "All",delalllb
Item "Current",delcrrlb
Title "Quit"
Item "Exit without del images",quit2lb
Item "Delete All Images",quit1lb
Item "Stop",haltlb
Title "About",aboutlb
EndTBar
Cycle © to Loop
Lbl regpollb:
If polytype <= 2 Then
polytype→chspolvl
EndIf
PopUp {"Tetrahedron. 4 Faces","Hexahedron (Cube). 6 Faces","Octahedron. 8 Faces","Dodecahedron 12 Faces", "Icosahedron. 20 Faces"},chspolvl
If chspolvl = 1 Then
0→chspolv
Dialog
Text "Tetrahedron is one kind of pyramid"
Text "composed of 4 triangular faces."
EndDlog
poltype(1)
Else
If chspolvl = 2 Then
0→chspolv
Dialog
Text "A cube is a hexahedron with all"
Text "its faces square and three squares"
Text "around each vertex."
EndDlog
poltype(2)
Else
If chspolvl >= 3 and chspolvl <= 5 Then
0→chspolvl
Dialog
Text "Algorithms still not created,"
Text "will be included in future releases."
EndDlog
EndIf
EndIf
EndIf
Cycle © to Loop
Lbl othrpolb
If polytype >= 6 Then
polytype-5→chspolvl
EndIf
PopUp {"Square Pyramid. 5 Faces","Triangular Prism. 6 Faces"},chspolvl
0→chspolv
Dialog
Text "Square Pyramid is a pyramid, "
Text "having a square base"
EndDlog
poltype(6)
Else
0→chspolv
Dialog
Text "1"
Text "1"
EndDlog
poltype(7)
EndIf
EndIf
Cycle © to Loop
Lbl wparamlb:wparamts()
Cycle © to Loop
Lbl wparm2lb:wparamt2()
wparm2lb
Cycle © to Loop
Lbl wparm3lb:wparamt3()
wparm3lb
Cycle © to Loop
Lbl dftparlb:dftvalue()
Cycle
Lbl makeimlb:makepict(nimages,highpoly,dcrhigvl,hidedgvl,rotatnvl,axesflag,vertexfl,polytype)
Cycle © to Loop
Lbl startalb:exeanimt(nimages,anidelay,maxcycle,rotatnvl)
Cycle © to Loop
Lbl delalllb:delpics(nimages,1)
Cycle © to Loop
Lbl delcrrlb:delpics(nimages,2)
Cycle © to Loop
Lbl aboutlb:aniintro()
Cycle © to Loop
Lbl quit1lb:exitprgm(nimages,1)
Exit © to EndLoop
Lbl quit2lb:exitprgm(nimages,0)
Exit © to EndLoop
Lbl haltlb:Stop
Exit © to EndLoop
EndLoop
EndPrgm
+1
